02-22-2014, 07:25 PM | #1 |
Rep 570
Di and valve crudding
2 series forum member and prospective m235i buyer here, and I was wondering if the the N55 has major problems with valve crudding due to it not having a dual injection system. Do most 135 owners run into this problem? At how many miles, and what does it cost to fix?
TIA. |
02-22-2014, 08:40 PM | #2 | |
Rep 6,478
F30 N55 XDrive EBII |
02-23-2014, 07:59 PM | #3 |
Rep 234
Valve cleaning should be routine maintenance on any DI car. Cost will depend on your location. Search around a bit and start to build a relationship with an Indy who works on these vehicles.
PE exhaust, tints...more to come
02-27-2014, 11:18 PM | #4 |
Rep 435
02-28-2014, 12:23 PM | #5 |
Rep 1,026
Interesting. What strictly DI motors do not suffer from carbon build-up? I know Toyota has used a combination of DI with port injection to prevent carbon build-up, but I have not heard of any DI only engine not having carbon issues.
02-28-2014, 01:00 PM | #6 | |
Rep 919
Supposedly Ford has "solved" the problem through different injection timing just like Mazda fixed it with temperature management on the intake valve. Both seem to still experience issues, albeit not to the point of the N54. |
02-28-2014, 01:04 PM | #7 | |
Rep 1,026
02-28-2014, 04:24 PM | #8 |
Rep 435
The Toyota port/di injection approach is for better gas mileage....reducing carbon buildup is a bonus. At higher rpms port injection is more efficient than di. There's been a lot of research done on carbon buildup with di motors and the results are interesting. The buildup has been analyzed and it turns out to be mostly coming from the gasoline being used in the US. "They" say the problem isn't noticed in Europe. It seems we/US have crap in our gas that they don't. But by playing with valve timing/overlap, piston crown shape, valve location etc. it can be minimized even with the crummy gas. It's the unburned gas that backs up into the intake track and gets cooked on hot valve and intake track that becomes the buildup. With no fresh charge to clean it off it grows. There's several cars that don't suffer the malady in the US and they don't use the port & di set up.
02-28-2014, 05:48 PM | #9 | |
Rep 1,026
04-18-2014, 06:29 PM | #10 |
satch
39
Rep 1,040
Another one bites the sludge.
Mines at the dealer right now getting a $700 cleaning. 2009 N54 with 50,000. Always run hot since I drive 25 miles each way to and from work at about 75 to 90 miles an hour in desert heat. Still crapped up.
"The Dingo ate your Mustang" |
