      04-19-2018, 04:22 AM   #1
wba116i
Drives: e87 2007 116i
oil level sensor accuracy?
this is my first BMW so please bear with me. i have a 2007 116i - Last week while driving back from another city 'low engine oil' sign popped up and it suggested to add 1L oil. I freaked out and stopped my car to check for any visible leakages (didn't find any). And the very next day in the morning before leaving for work - i checked the oil level and it said oil level OK (right in the middle of the gauge on the dashboard). I decided to take the public transport - being unsure of the oil level readings. The reason i freaked out was because i had a oil change 6 months ago (have driven 2k km since) - when i bought the car it had 166k on the meter and now its 168k.
So, i added 500ml oil yesterday and drove for about 10km and checked the level which showed 'FULL' (image 1). and at the end of journey (50km) - the oil dropped to 80-85%(image 2).
Whats happening here? I am freaking out. Should i be worried?
      04-19-2018, 05:40 AM   #2
GarnZ
GarnZ's Avatar
Drives: 120i E87 MY09
I found the indicator to be extremely accurate.
A couple of things you might want to observe...
* Always check after the engine is completely warmed up.
* Always check on level ground.
I found a litre of oil will fill from the low mark to the upper mark.
!/2 way to upper mark is 500 ml.
Check for oil leaks on ground.
Sniff engine for oil leaks after a steep driveway, The oil from the cam gasket can drip onto exhaust creating an oily smell.
RegardZ
      04-19-2018, 05:43 AM   #3
wba116i
RegardZ
Should i fill up further 200-300ml? What do you reckon could be the reason for reading deviation?
P.S: I checked after warming up the engine and on a flat surface!
      04-19-2018, 05:51 AM   #4
GarnZ
GarnZ's Avatar
if you see the oil-can light, indicating low, and the car is warm, with motor running pull-up on a flat section of road and check, if its half way forget it, there will be plenty to get you home. Check another day and see if it is substantially different.
RegardZ.
