04-09-2015, 06:15 PM | #1 |
Rep 177
Damn, did i get screwed?
So after all the fun of the new AA tune, etc, i take car in for oil change. Which has turned into replacing plugs, valve cover gasket, oil pan gasket, oil filter housing gasket, coolant flush and a bill of $2500!
Granted the car is only serviced by the local dealer, but damn, did i get screwed? 2008 128i, 90k miles, auto/paddle shift, AA tune, K&N (charcoal delete), aFe scoops. Oh, the dealer also just got in a 2014 M235i with 9k miles on it...they think i should trade mine in on it. Nope! |
04-09-2015, 06:37 PM | #2 |
Rep 4,040
Drives: 130i coupé ;)
That's a lot of gaskets. But a lot of miles so it balances it out
Some of those could have been Diy repairs. Without knowing your dealer mechanics rate it's also hard to see if they took too long
04-09-2015, 09:55 PM | #4 |
Rep 701
I think plugs are typically replaced around 80k, sometimes sooner. You might make sure they aren't exceeding the recommended oil capacity on your oil changes.
04-10-2015, 08:18 AM | #6 |
Rep 177
i am pretty many of the things could have been DYI... valve cover gasket, possibly oil filter housing gasket & plugs.
oil pan gasket... nope! after watching what the tech had to go thru and not having access to a lift, oil pan gasket would not have been a job to do. not sure i could do a coolant flush, considering i live in a apt complex and dont have a garage. i asked to do the oil change early only because the car had just gone 1200 miles passed its check-up; the oil change was going to be needed anyway and putting 1800 miles of road trip, i figured now would be a good time. in the end, i may have paid a little too much, but knowing the hard work was done by a bmw tech at their shop (which has all the bolts, etc in stock which need to be replaced) is some piece of mind. i trust the tech, particularly since they do let me go into the shop, ask questions, see what is actually being done. and if i were to ever sell the car, all records can be pulled up from any bmw dealer. |
04-10-2015, 07:00 PM | #7 | |
Rep 272
Drives: 2008 128i
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
04-13-2015, 07:45 PM | #8 |
Rep 497
Did all those replacements from 75k-80k. My car seems good for another few thousand miles. But thank god mine was under CPO warranty
E82.Love | Magnaflow | aFe | H
04-14-2015, 07:10 AM | #9 |
Rep 6,989
Drives: 15 F80 M3, 22 G01 X3 30i
Swimjim - which dealership did you go to? Sounds like you paid about double what it should have been, and the need for the pan gasket sounds questionable. At that mileage, I would have taken it to an Indy shop where it likely would have cost less.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
04-14-2015, 10:08 AM | #10 |
Rep 177
i brought it to the local dealership. during the inspection before the work was done, i did get a chance to see the oil pan and it was leaking around the gasket. the oil filter housing had residue around it so i knew it had to be changed. as for the valve cover gasket, hard to say since its all covered up with plastic!
i may swing by a local bmw shop and get an estimate from them for a comparison. |
04-14-2015, 12:08 PM | #12 |
Rep 177
i have not been by another shop yet, but here is a list of work done...
- vehicle check - standard oil change - new spark plugs - coolant flush - oil pan, oil filter housing, valve cover gaskets - aluminum screws - labor for all total - $2371. labor was $1868?!!! parts were just $480. i dropped the car off at 10:30am one morning and pick it up before lunch the next. i shoulda gone to bmw tech school! Last edited by Swimjim; 04-14-2015 at 01:28 PM.. |
04-14-2015, 01:11 PM | #13 |
Rep 457
What is the shop's labor rate? I'd guess around $120/hr but that's over 15 hours of labor for $1800 worth of labor charges. They might be charging book times for each job instead of actual time.
Does the front subframe have to be dropped to access the oil pan? If so, that could be a major contributor to the high labor charges. |
04-14-2015, 01:27 PM | #14 |
Rep 177
yes, the subframe had to be dropped to change oil pan.
as for total hours of labor, the bill does not state. i would assume tech worked on car from 10:30am-5:00pm with a break for lunch or about 6.5 hours one day and then maybe 3 hours the next. Last edited by Swimjim; 04-14-2015 at 01:35 PM.. |
04-14-2015, 02:38 PM | #15 |
Rep 457
Did you ask the service writer or service manager about your bill and why it is so high? They should provide a detailed breakdown of costs for each item on the ticket.
04-14-2015, 03:03 PM | #16 |
Rep 250
120 dollars an hour is an absurd amount of money for a mechanic. I don't know whats normal in the US but here in Holland mechanics cost 50 euros an hour (half of the rate you paid).
BMW E88 125i - Tunex Tuned@ 228whp - Cyba Scoops - Performance Kidneys - Performance Exhaust - Performance Intake - BMW Strutbar - 3d Design Carbon Diffuser - Blacklines - Golf Tee - FK Coilovers - Klutch SL14
04-14-2015, 03:11 PM | #17 |
Resident Tamed Racing Driver
298
Rep 4,697
Oil pan gasket is a pretty involved job. The other items are pretty quick/easy.
04-14-2015, 03:13 PM | #18 |
Resident Kerbalnaut
477
Rep 10,703
It depends on the region, but in NY dealers charge $130-150 and Indy shops charge $100-120
04-14-2015, 04:02 PM | #19 |
Rep 374
That sounds sound like Seattle as well. I was quoted ~$140/hr for labour cost at my local BMW dealer.
New Car: 2019 Porsche 718 Cayman GTS | Stock for now Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA |
04-14-2015, 06:33 PM | #20 |
Rep 3,856
I couldn't help it:
04-14-2015, 07:12 PM | #21 |
Rep 1,026
04-14-2015, 08:09 PM | #22 | |
Rep 22,992
In Germany most BMW dealerships charge 100 to 130 euros per hour for COD(customer paying) work. Most indi's charge 50 to 70 euros. But as the saying goes... you get what you pay for. My BMW Zentrum often charges way less time per job, than my little indi shop. My indo shop charged me one hours labor to change my oil on my e39. At my BMW Zentrum that would only be a half hours job(sometimes less when they have a special sale). That said... I almost always do all my own work/maintenance work. Back in the day('90's) when I worked at a VW dealership... we charged $65 per hour. Of that $65 dollars, the tech would get(maybe!) $23. Maybe. I think depending on where you live in the USA... most dealers charge between $90 to $160. The higher rates being in Cali or NY/Boston. Dack
