      08-25-2016, 02:20 PM   #1
VRG_135
Drives: 2012 Silver 135 DCT
$719 for an intake boot?!?
2012 135. Does $719 (dealership) sound right? Even the independent shop I called said the part alone would run almost $400. Seems excessive for a hose.
Thanks ahead of time for your advice....
      08-25-2016, 03:07 PM   #2
Downeaster1
BMW Master Tech
Downeaster1's Avatar
Drives: E30, E36, E82, E90, F10, F80
These cars don't have an intake boot...the charge pipe plugs directly into the throttle body. Do you have a part number for the piece you are talking about?
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad
      08-25-2016, 03:23 PM   #3
VRG_135
Here is what the dealership sent me....
Intake boot PT# 13.71.7.615.026 $345.40
Labor 2.0 hours (including diagnosis) $327.60
Tax $28.50
Shop supplies $18.00
Total $719.50
This part is not covered by BMW extended warranty either. It is a boot, which is considered a wear and tear item. Most warranties only cover mechanical or electrical parts that have failed. (As opposed to just wearing out over time like a boot)
      08-25-2016, 03:42 PM   #4
NorthernDancer
There is something very wrong here if this part failed in only 4 years. Has a previous owner been in there doing and undoing mods? Your in a big city-there must be a number of very good indies there. BMWCCA membership gives you access to a huge amount of free technical advice. BTW, Bav Auto charges $329.95 for this (free shipping and no tax in New Hampshire). You have Autohausaz and they are good too.
      08-25-2016, 03:50 PM   #5
VRG_135
Cheapest ind. garage was $200 cheaper, but I have to pay $165 to dealer for looking at it. Not really worth it.
      08-25-2016, 07:16 PM   #6
Downeaster1
BMW Master Tech
A charge pipe failing is a fairly common occurrence. N54 ones are more prone to failure, but if you are replacing it, you might as well get an aftermarket upgraded one. I'd go with a metal one to be honest. You can even find a do-it-yourself guide online here. It's not a difficult swap at all.
135is #502 of 586
      08-25-2016, 08:23 PM   #7
mackeroni
Former Opel GT Pilot
mackeroni's Avatar
Drives: 2011 135i, AW, CR, 6MT
Found the part for $255...
http://www.bmwpartswholesale.com/oe-...FQYPaQodVWgJIQ
So, that's it. I am doomed. There is no patch, no methadone, no substitute. Curse you BMW. Curse you and your seamless power delivery. Curse the incredible sense of road feel. Curse the comfort, the luxury, the envious looks from the masses. I am... hopelessly addicted.
Dackelone10588.50
      08-25-2016, 11:21 PM   #8
Boostedbean
Just pay dealer the $165 and find someone local selling a stock charge pipe. Or, order an aftermarket one to not worry about failure anymore. It only takes about twenty minutes to install a new charge pipe on the N55. I'm in Dallas also and would be happy to help you.
      08-26-2016, 09:34 AM   #9
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Just get an ER or vrsf charge pipe and call it a day. 719 is ridiculous.
      08-26-2016, 02:20 PM   #10
brocklanders
brocklanders's Avatar
106
Drives: the uno, mineral white
06 325  [0.00]
Mine popped at 20k miles, this is a known flaw. It is ridiculous that extended warranty won't cover it. If you are hard on your throttle at all I would not replace with stock unless you want to do this every so often. Just because the first one lasted four years doesn't mean the next one will. The one that blew wasn't worn down, it was weak to begin with and finally gave.
      09-12-2016, 03:55 PM   #11
doublevanosrc
Loves his G20
doublevanosrc's Avatar
265
Drives: 2020 330ix M sport
2013 BMW  [0.00]
How common is this?? Does it set off a warning light to let you know it needs replacing? It's absurd that warranty won't cover it, I wonder if a 3rd party warranty would cover it? Seems like BMW's CPO covers less and less each year.
2020 330ix-Msport
Past-
2013 135i
2011 135i
      09-12-2016, 04:03 PM   #12
50shadesofhockenheim
50shadesofhockenheim's Avatar
Drives: 2005 Toyota Prius
And 2017 models will only have 3 years/36k mile warranty
http://www.bmwusa.com/Standard/Conte...eoverride=true
      09-12-2016, 04:08 PM   #13
doublevanosrc
Loves his G20
265
2013 BMW  [0.00]
Maintenance warranty yes, I guess those profits aren't as big as they used to be.
2020 330ix-Msport
Past-
2013 135i
2011 135i
      09-12-2016, 07:51 PM   #14
TX135i
Drives: 2012 135i Coupe DCT
Extended warranty covered mine when it blew up (the second one in 14 months by the way). Original lasted 3.5 years but the second one just over a year.
      09-12-2016, 07:56 PM   #15
VRG_135
No, no, & no. It's the charge pipe, I would've changed it myself if I had the problem originally. I was confused by the term "boot "
      09-14-2016, 03:01 PM   #16
nantucketsleigh
Drives: '10 X5M, '13 135is, '92 500E
Same part failed on my 2013 135is. Car just cracked 8K miles and was still under warranty. SA suggested replacement with after market HD part when out of warranty. Said that they seem to get a failure or 2 every week on newer N55 engined cars. My experience with my local dealer's service has been good but its pretty depressing that BMW has not fixed this issue with an improved part.
VRG_135836.50
      09-14-2016, 03:25 PM   #17
A failed/cracked CP is very common. More so on N55's for some reason. But they all fail sooner or later. They normally break at the plastic welds at the throttle housing/clip.
No real codes... unless your cp is cracked only slightly... then you might get a 30FF boost code - bc your engine can't produce the boost pressures your DME is asking for. Most common sign is oil/dirt on the intake hoses/plumbing.
mackeroni326.50
