      05-14-2018, 11:01 PM   #1
f82_spooly
Drives: F82 M4, E92 M3, E46 M3
VMR V703 wheel fitment?
I'm looking to purchase a set of V703 wheels for my 135i I currently have no drop so I'm stock height M sport suspension and my tire sizes are 225/40/18 in the front and 255/35/18 in the rear. The specs of the wheels I'll be buying are
18x8.5 +40 in the front
18x9.5 +45 in the rear
Will I rub in the rear being stock height and with a 35 profile tire?
Should i instead get a 18x8.5 +35 in the front and will I have any problems?
These are what the wheels look like btw.
      06-26-2018, 01:02 PM   #2
VMRWheels
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Sorry we missed this post! In case you never got the answer you were looking for, the rear would likely rub under compression. We normally recommend a 245/35/18 tire on the ET45 rear.
For the front, we normally recommend ET40-45 with a 225/40/18 tire.
Hope this helps! Apologies again for the delayed reply!
      07-07-2018, 09:05 PM   #3
Sliiiiick
Drives: 2011 AW 135i 6MT
I currently run 255/35/18 in the rear with stock m sport suspension no problem at all.
      10-15-2021, 01:58 PM   #4
Apexpixel
Apexpixel's Avatar
Drives: 2012 BMW 135i
Anyone have an update on whether the 18x8.5 ET35 will be too tight in the front? Would be running a 225/35/18 tire with it. Also have a line on someone to roll the fenders properly. Just curious if additional rubbing occurs due to fender lining, etc? Many thanks!
      10-15-2021, 02:00 PM   #5
Apexpixel
Apexpixel's Avatar
Did you end up running this set up on your 1er? Any feedback on fitment/challenges? Thanks!
      10-17-2021, 08:11 AM   #6
Petro135
Drives: 2008 135i E88
2008 BMW 135i  [0.00]
I replied in your other thread. You should have no issues with that setup. I had 225/40 and 245/35 and never had any rubbing at all. Then I went to 255/35 in rear and only rub on big dips in the road with the rear. Im going to pull the rears and roll the fronts and put 235/275 summer tires in the spring. For the winter I'm on Conti dws06
      10-17-2021, 11:46 AM   #7
Eyeman
Eyeman's Avatar
121
There are tons of 10 yr old threads about these size wheels. For sure the et40 front wheel is a better choice and is about the best size you can get. Tire brand, camber, lowering, and even strut brand can somewhat effect what will fit your car.
      10-28-2021, 10:52 AM   #8
Apexpixel
Apexpixel's Avatar
Really appreciate the input here. Pretty much dialed on a set up at this point. Going to run out the current tires on the car with a track day in December then make the switch! 👍🏼
