      04-07-2012, 08:22 AM   #1
-cj-
Drives: '20 X5MC | '20 Z4
Comfort access issues
Hey gang,
Does anyone have problems with their comfort access not always working 100% of the time? I'll reach for the door handle and nothing happens. I'll then try with the other hand, twisting my body and moving the key around (which is in my pocket) and sometimes that helps. Other times I look like an idiot and eventually just grab my key and manually unlock it.
Also happens with my trunk. I'll hear the mechanism but nothing happens.
Is this normal or is my key defective? I charge it periodically but I've never received a low battery warning.
Current: <pending> | '20 Z4 M40i
Past: 09 M3 Coupe DCT (sold) | 11 1M Coupe MT (sold) | 15 i3 REX (returned) | 15 X3 35xi (sold) | 16 M235xi Vert (returned) | 18 M3 Comp Ultimate DCT (sold) | 20 X5 M Comp (totalled)
      04-07-2012, 08:34 AM   #2
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
I believe this is normal for the 1 series. CA worked better on my 5 series, especially for the trunk.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      04-07-2012, 08:46 AM   #3
sochermit
Drives: 2003 325i, 2012 135i
Curious: Do you have window tint? If so what kind? I have heard, not from many, that some window tints, especially those with metal, may interfere with comfort access.
      04-07-2012, 08:53 AM   #4
OAM
OAM's Avatar
Drives: Sitting
I have window tints and CA works the same as it did for me before. The only issue I have is figuring out a way to have ca unlock both doors.
      04-07-2012, 08:58 AM   #5
sochermit
I believe the fob has to be programmed to work that way. You may have to take it to a dealer to change the settings.
      04-07-2012, 09:05 AM   #6
-cj-
I'm using SolarGard NR Charcoal tints, 17%... But they aren't metallic TMK. I think the HP series is, though. It works sometimes though, wouldn't that suggest it's something else?
OAM: It's a setting in iDrive. Under locks I think. Something about unlocking just drivers door or both doors when hitting the unlock button. Also applies to comfort access.
      04-07-2012, 09:16 AM   #7
saurabh_turingMS
saurabh_turingMS's Avatar
Drives: 1M AW (F10 520D MSport - gone)
I optioned my car with CA, hoping it's worth it...
      04-07-2012, 09:27 AM   #8
-cj-
It works 90% of the time. Just have your key ready so you don't look ilke an idiot reaching for the door handles endlessly lol.
      04-07-2012, 09:38 AM   #9
Jezzer
Drives: Series 1 m coupe
Yeah mine doesn't always respond, but only occasionally.
      04-07-2012, 09:42 AM   #10
Sheil
Sheil's Avatar
Switzerland
25
Drives: 1M Coupe
2011 BMW 1M  [10.00]
Make sure you insert the key fob next the start/stop from time to time to recharge it. Decreased charge -> decreased reliability.
      04-07-2012, 09:59 AM   #11
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
In my case, it works all the time problem free if the car is in my garage or at the work place garage, but for example in gas stations and some other places that I assume with interference issues the car usually fails to start again without the key in place. In general, I don't call it a problem, already got used to it, and CA is one of the options that I am glad to have.
      04-07-2012, 10:05 AM   #12
OAM
OAM's Avatar
Drives: Sitting
Thanks! Going to go take a look now.
      04-07-2012, 10:10 AM   #13
sparoz
sparoz's Avatar
Drives: VO 1///M; Macan Turbo
CA keys doesn't have rechargeable battery like a normal key. Putting it in the slot does not recharge. You can change to a new battery if not working well and may work better.
Macan Turbo - White
1///M - Valencia Orange
      04-07-2012, 10:22 AM   #14
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
Sound like you do have a problem. I've never had an issue starting any of my BMWs with CA. Only issue is with unlocking doors and trunk.
Anyone else with CA experiencing issues with starting without inserting the key?
2017 F80 M3/AW
      04-07-2012, 10:31 AM   #15
ozinaldo
ozinaldo's Avatar
Portugal
116
Drives: 1M
It is always in gas stations here, for example I go there, the key is in my pocket, I fill in, pay and when I get inside the car again and press the button, it reads like there is no key in place with the relevant image appearing, then I put the key in and it works. Never happened any other place so I am assuming the car is loosing the signal when I get out and move away a little bit to pay etc. and failing to restart. I will try next time leaving the key inside the car if I feel that it is safe there or if I am with second key also (in case).
      04-07-2012, 11:11 AM   #16
Aetey
Aetey's Avatar
Luxembourg
Drives: M Coupe
Beh it's not a 1 series thing, CA on my Porsche is picky too. Works 90% of the time, usually doesn't when it could have been actually useful (raining, carrying bags weighing a ton, key fob lost in a gazillion possible places, group of nearby blondes looking over...)
Although I have to say that CA is one of those things that once you get used to it you realize it's missing when you don't have it.
      04-07-2012, 11:40 AM   #17
Dee Pee
Dee Pee's Avatar
176
Drives: '11 AW 1M, ‘24 718 GTS
I mostly have this issue if my cellphone is in the same pocket as my key. it works most of the time however.
      04-07-2012, 12:12 PM   #18
HERR FSTIR
HERR FSTIR's Avatar
Drives: LBB M2C, VO 1M, GSA 1200
+1. CA working inconsistently has a very strong correlation with cell phone proximity to key fob.
      04-07-2012, 12:45 PM   #19
EINSER M
EINSER M's Avatar
Drives: BMW i3 rex
+1 some random non functioning of the CA and i have a limo tint
      04-07-2012, 01:05 PM   #20
jkoral
Drives: 2017 M2 LBB 6MT
That would annoy me. I don't have it on my 1-series (although I wanted it), but I do have it on my Japanese Crossover. It has never failed to open the doors or start the car. I can't imagine it not working 100%.
      04-07-2012, 02:52 PM   #21
doug_999
doug_999's Avatar
2545
Drives: 2011 1M/2021 992/2023 X3
If you have your phone in the same pocket as the fob you will occasionally get this type of behavior, especially if the key is behind the phone.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual
2023 X3 M40i - loaded sans Park Assist
      04-07-2012, 06:26 PM   #22
1SerieStud
1SerieStud's Avatar
184
Drives: '11 VO 1M (498 of 740)
Mine works 100% and I have tinted windows, but I have carbon tint so no metal in it. The metallic films are apparently the ones that affect CA performance.
