09-29-2013, 08:47 AM | #1 |
Lord Captain Commander
110
Rep 3,093
Severe shuddering during cruising and braking
So driving today I realised something wasn't right with my car:
The thing that confuses me is that all this goes away as soon as I touch the throttle, but it seems quite obvious that something is wrong in the drivetrain. Tried going up and down my driveway tonight and there is definitely also a distinct "thump" everytime I brake, which leads me to think that it is a problem in the wheels/suspension. Any ideas what this could be? Thanks in advance for the input.
E82 135i M-sport: SGM/6MT/Black |
09-29-2013, 08:53 AM | #2 |
Rep 2,682
Hmmm I have no idea what it could be but I don't think it's to do with the wheels or the suspension. If it were, it would happen at all times. If it only happens when coasting out of gear or when braking it sounds like something that happens only when the engine and transmission isn't being loaded so I'd guess that the problem is something to do with either the engine or more likely the transmission.
Of course I could be totally wrong.
09-29-2013, 08:54 AM | #3 | |
110
Rep 3,093
But then I don't get why it also happens when everything is in neutral and I brake with some force, which is why I was led to believe it was outside the drivetrain.
09-29-2013, 06:51 PM | #4 |
Rep 6,285
Sounds weird, and difficult to diagnose going on the description!
So obviously no codes? I was getting slight jerking stumbling at low revs (i.e coming into a tight corner under no acceleration just coasting) and new vanos solenoids and o2 sensors sorted that out but from what you describe it sounds like its a driveline issue? Does the clutch feel fine? IS the noise coming from the rear (I'm thinking diff possibly?) |
09-29-2013, 11:06 PM | #7 |
Big Mouth No Filter
49
Rep 586
I think it may be the driveshaft. Guibo? I had a Z3 used to do that a little between shifts,
Just a thought...
We do not inherit the Earth from our parents; we borrow it from our children
09-29-2013, 11:20 PM | #8 | |
110
Rep 3,093
Yep car's going in tomorrow. Idles fine and I looked around for a vacuum leak but to no avail. Good point, will get that checked out when the car goes in.
10-02-2013, 04:26 AM | #13 |
110
Rep 3,093
Turned out to be a loose rear left wheel. Someone had kindly undid all the bolts (except for the locking nut) when my car was parked on Saturday.
10-02-2013, 07:37 AM | #14 | |
Rep 6,285
At least that's an easy fix, but could have turned out nasty!!!! |
10-02-2013, 07:36 PM | #16 |
160
Rep 1,460
10-02-2013, 08:12 PM | #17 |
Rep 1,147
10-02-2013, 10:31 PM | #19 |
FULLY!
Rep 334
