      08-09-2015, 10:34 AM   #1
1Hokie
Drives: 08 328i, 10 z4 35i
Injectors Coding
So, I'll probably be replacing some of my injectors soon and I read it will require coding.. Found a good youtube guide and a few posts on using INPA, but I must be overlooking where to get the actual values to put in? Is it calculated or the same? I was thinking about reading my current values and using those, but if my injectors are bad, is this a bad idea as well or are the readings what they "should be", just the injectors aren't performing that level which is why I go into limp mode?
Any help on the values to use when coding would be greatly appreciated! 08 128i N51
      08-09-2015, 01:28 PM   #2
Adam135
Drives: 2014 435i
The values are printed on the injectors themselves. That's why the coding is necessary, to fine tune things exactly to the injectors.
      08-09-2015, 01:42 PM   #3
fastdrivingjr
Drives: ducati 749
^ he's right... If you watch those videos they tell you exactly every step. Watch the whole video do thorough research everything's here for you. I just did all of my injectors. Used what i learned online and my car runs better than when i bought it...
Google n54 injector coding
