      04-09-2015, 05:31 PM   #1
Segments
Aspiring 1'er
Segments's Avatar
78
Drives: 2008 BSM 135i
Where to get (tire)bead leak fixed ?
Hey , so I noticed the psi drop on one of my summer wheels. Checked it out, and the top beading has a leak. Where would you guys suggest I get it fixed on LI ?
      04-10-2015, 08:01 AM   #2
Zombie1
Drives: BMW 135i 2010
Any tire shop can fix it most likely. They'll have to break the seal put some bead liquid sealer on it fill it up with air then you'll be alright.
      04-10-2015, 08:27 AM   #3
MightyMouseTech
MightyMouseTech's Avatar
4338
I recommend not using bead sealer. If the bead of the rim and tire are both clean, it will not leak.
      04-10-2015, 08:42 AM   #4
Segments
Aspiring 1'er
Segments's Avatar
78
OK, I still think Im going to find a reputable shop regardless, I don't want them doing any more damage to this wheel. Thanks guys .
      04-10-2015, 05:34 PM   #5
edisapimp
Civil Rights Activist
Drives: E46 Sedan, E88 Vert
Rayda tires on suffolk ave. in brentwood. Best.
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame.
BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets
      04-10-2015, 05:37 PM   #6
IF your tire shop used a pry bar on your old RFT to remove them... they could have damaged your rim/wheel. I would have someone take a real close look at the wheel.
I agree with MightyMouseTech
      04-10-2015, 05:45 PM   #7
Segments
Aspiring 1'er
Segments's Avatar
78
Sorry guys, should've posted. The whole tire was poorly bead sealed, was completely bitten through. Getting new front tires this weekend I guess
