      09-09-2015, 12:44 AM   #1
wjk_glynn
wjk_glynn's Avatar
167
Drives: 997.2 C2S Coupé
Square 264s :: 18x8.5 ET52 front & back, with 245/35R18 RE050A RFT tires all around
Hi folks,
Many on this forum have noted they’ve installed Square 264 (or 313) rims with success. But when I’ve searched around, there doesn’t seem to be a ton of photos/specifics – at least in comparison to Apex and VMR installations.
So just for reference, here's my (no-rub) setup and experience… for what it’s worth…
Suspension Setup
Rims, Tires and Spacers
  • 4x 18x8.5 ET52 Style 264 rims
  • 4x 245/35 R18 Bridgestone RE050A RFT tires
  • 4x 10mm hub-centric spacers from Burger Motorsports
Alignment
  • Front:
    -2.2° negative camber, 1/32" toe-in per side, 7° caster
  • Rear:
    -1.8° negative camber, 1/16" toe-in per side
Ride Height
  • After installing the suspension parts listed above, I measured the following average drop in ride height as compared to the ZSP sport suspension with ~70K miles:
    - Front: 9 mm drop
    - Rear: 15 mm drop
  • The Dinan camber plates are ~6.5 mm thick and add to the stack height of the front suspension
  • This implies that the BMW Performance Suspension actually drops the suspension height by an average of 15 mm, more than the 10 mm per BMW’s product specifications
  • Visually the drop looks pretty even front to back, at least to my eyes
Clearance
  • The fenders are stock, with no rolling/pulling
  • The car has been driven over a variety of roads and conditions and there doesn’t appear to be any rub
  • Front:
    - Visually it looks extremely close from the tire to the outside edge of the fender, I'm kinda amazed there isn't rub
    - Can’t imagine fitting any wider tire, at that camber angle
    - Clearance between the front rim & tire to the strut is somewhere between 1/8” and 1/4" (i.e. ~5 mm) - measured using the feel blindly and guess technique
  • Rear:
    - At the beginning, I had 12 mm spacers in the rear but they rubbed under conditions of heavy suspension compression
    - Switched to 10 mm in the rear, same as the fronts
    - No problem since
Driving Impressions
  • Steering feel comes across as having a bit more stiction
  • No perceptible change in ride quality
  • Understeer is significantly reduced, but not eliminated
    - Don’t know how much is due to wider front rims/tires, or increased camber
  • Really the big change is that you can get the nose to point in more quickly, thus greatly increases confidence (at least for me)
There you have it.
Karl.
PS: And now a few pics (please excuse the dirt):
  • #5 and #6 show the front fender clearance
  • #7 and #8 the rear…
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers
Last edited by wjk_glynn; 07-04-2016 at 12:16 PM.. Reason: Add note about where the spacers came from...
gixracer277.50
PKT RKT27.00
      09-09-2015, 06:19 AM   #2
lowbudgethero
lowbudgethero's Avatar
125
2009 BMW 135i  [8.50]
looks like they fit way better than my setup:
Suspension Setup:
Stock, free camber mod, M3 control arms
4x 18x8.5 ET52 rims
4x 255/35 R18 Dunlop Direzza ZII
Alignment:
not known
Clearance:
awful until I rolled the fenders and shaved the bumper tab, after rolling there are no problems
Driving Impressions (going from michelin PSS to Dunlop ZIIs as well)
Steering feel is heavier
No change in ride quality, a bit noisier
terminal grip is very high
      09-09-2015, 09:13 AM   #3
brocklanders
brocklanders's Avatar
106
Drives: the uno, mineral white
06 325  [0.00]
Hero, do you think in your experience if you originally went with 235/40 front and 245/35 rear Zll's you would need fender work with your setup?
      09-09-2015, 11:28 AM   #4
Elsabor67
aiming for 450.....
Elsabor67's Avatar
Drives: Totaled :-(
2009 135i  [10.00]
I run a 235/40 R 18 on mine and they are only for the track. Same wheels as yours.
Suspension: TC Kline D/A coilovers with Ground Control Camber plates and Swift Springs (400F/720R), M3 front control arms and sway bar, HP Autowerks adjustable end links, Eibach Rear sway bar, M3 rear trailing arms, Adjustable toe links.
Tires: Federal 595 RS-R with a 15mm Spacer up front.
My oversteer is literally non existent. And handles phenomenally on track. Camber up front is -2.8 with 0 caster and -2.0 rear. can't remember my toe.
      09-09-2015, 02:20 PM   #5
lowbudgethero
125
Nope, tbh i think 245s might have worked in the front if I had similar ride height but stiffer springs/shocks.
When I originally sized everything I was using PSS 245/35 tires
      01-27-2016, 11:58 PM   #6
hokejka
Drives: Past: 135i 6mt
Originally Posted by wjk_glynn View Post
Hi folks,
Suspension Setup
Alignment
  • Front:
  • Rear:
Ride Height
    - Front: 9 mm drop
    - Rear: 15 mm drop
Clearance
  • Front:
  • Rear:
    - No problem since
Driving Impressions
There you have it.
Karl.
thanks for sharing. something ive considered
      04-01-2016, 05:46 PM   #7
Gangplank
Gangplank's Avatar
2011 135i  [0.00]
Bringing up an older thread. I've been thinking about running a square set up and wasn't sure about running a set of wider rear rims in the front.
The BMWPS w/ M3 arms and Dinan camber plates is the exact suspension set up I've been considering so its great to hear it can be done!
Seems the difference here is alignment and tires. Good to know it is possible.
#1 No rub set up!
Suspension Setup
BMW Performance Suspension (p/n 33500444831, 31336788891 and 33536788898)
Dinan Camber Plates
M3 Front Control Arms
Alignment
Front:
Rear:
Clearance
Front:
Rear:
- No problem since
Driving Impressions
There you have it.
Karl.
#2 Oh No!
Originally Posted by lowbudgethero View Post
Suspension Setup:
4x 18x8.5 ET52 rims
Alignment:
not known
Clearance:
Setup #3 also works but narrower tires which I would expect to grip less, but added M3 front say and other parts + non-runflats, all which seem to have relieved even more understeer.
Which M3 front bar are you running - the E92 or E93 version?
Does adding the stiffer rear bar make a big addition or did you change it all to this set up at one time?
Suspension:
w/ Ground Control Camber plates
M3 front control arms and [M3] sway bar, HP Autowerks adjustable end links,
      10-09-2016, 05:36 PM   #8
wjk_glynn
wjk_glynn's Avatar
167
Just an update on clearance after fitting different tires...
I recently switched from the Bridgestone RFTs to the following square setup (no other changes):
4x Hankook Ventus RS3 235/40 R18
Everything else is the same.
However... with these new tires I now have some rubbing up front where the front passenger tire rubs against the back of the oil cooler vents at larger steering angles (e.g. maneuvering around parking lots).
I think the reason is that these new 235/40 tires are taller than the previous 245/35 RFTs, and so they're just that bit closer to the vent.
Because the rubbing doesn't happen with regular driving, track days, etc. (just at large steering angles), it's acceptable to me.
But just wanted to share for others with square 264 setups...
Karl.
      10-10-2016, 02:56 PM   #9
Elsabor67
aiming for 450.....
Elsabor67's Avatar
Drives: Totaled :-(
2009 135i  [10.00]
#1 No rub set up!
#2 Oh No!
Hey @Gangplank, The tires sizes are really ideal and aired to 34PSI all around. Once warmed up they stick very well and provide good feel and feedback. The rear bar provided a slightly stiffer rear but is still compliant and works really well keeping the back planted together. I am running the E92 front sway bar.
This was literally my 4th suspension setup and had just switched out from a AST 4150 single adjustable with Swift springs. Before then, I had H&R super sports on stock struts and then a Eibach Pro Kit with dampers and springs. Then I did the sub frame bushings, then the M3 control arms, then the AST with Vorshlag plates and now the TC Klines with Vorshlag plates.
Gangplank1540.50
      10-10-2016, 07:52 PM   #10
500AF
Drives: 2013 135
With the 8.5 261m wheels it appears to run on the strut. Very close with the 10mm spacer. Not sure how to get around this problem - I think 12mm spacers would not work on the fender.
      10-11-2016, 01:07 PM   #11
Elsabor67
aiming for 450.....
Elsabor67's Avatar
Drives: Totaled :-(
2009 135i  [10.00]
Yes they will fit. I can run either 12.5 or a 15mm. The 15mm though, depending on the tire will rub not on the fender but on the inner bumper cover under full compression. I run 235/40-18 and mine rub on the upper edge of the bumper cover. Another thing you may want to do if you have not done so is do the M3 control arm swap. Add's a degree and a half more of camber (more or less). Camber plates are another option also.
I plan on trying the 12.5 for next track season here. That is a shot of my car coming into Brunnchen (Nurburgring).
      10-12-2016, 11:37 AM   #12
500AF
Drives: 2013 135
Thanks for the response. So are you saying the 12mm ones will fit?
The 10mm ones are rubbing. I did order the 12mm ones to try.
Sounds like I need to get the m3 control arms.
I really want to get this to work, thanks!
      06-09-2017, 02:04 PM   #13
TridenTBoy
Drives: 2013 BMW 135is
2013 BMW 135is  [0.00]
Anyone know if I can run square 8.5" (rear) 313s on the whole car? It probably would help a bit with tire longevity (assuming I don't have to go crazy with camber or what not?) and it'd cut down on the understeer. I'm just curious as to what it would take to do and what compromises there are with doing that.
Are there any issues with running 8.5" in the front besides possible rubbing? Would it affect handling or how the suspension performs overall?
I was trying to remember my physics classes but I thought I'd hear from anyone who knows more about this topic than me.
I'm on a 135is, if that makes any significant difference.
      06-13-2017, 04:07 PM   #14
lowbudgethero
125
You need 10mm spacers to make the rear 313s fit on the front, I'd stick to 245 tires unless you want to roll the fenders and shave some metal (ask me how i know ). My setup has a bit more tram lining that stock, but has way less understeer.
Everything was kosher with 245 Michelin super sports with just the strut tower camber mod. When I switched to 255 dunlops I would rub badly until I did some fender rolling/pulling.
      06-13-2017, 06:53 PM   #15
TridenTBoy
I think 245 would be fine. 255 would be nice but I don't feel like modifying the car in such a way that isn't reversible. Although, 245, they are harder to come by in my experience. Are we talking 245/35R18?
      06-15-2017, 10:17 AM   #16
lowbudgethero
125
Yeah, 245/35/18. It did pain me to do that on a relatively new car at the time.
I think the dunlops are also just wider in general because of a square shoulder profile.
      05-08-2018, 07:23 PM   #17
500AF
Drives: 2013 135
Resurrecting this thread. I finally got around to order the bmw performance suspension kit. I am still trying to figure out how to get the square setup in the front. Mine rubbed with the stock suspension and 10mm spacers.
Does the OP or anyone else no if I still want to do this (square setup) should I add the camber plates and m3 control arms? It did not work with the stock suspension and 10mm spacer.
Since it will already be apart I might as well add it then so I can do the square tire setup.
      05-08-2018, 07:55 PM   #18
wjk_glynn
wjk_glynn's Avatar
167
...Does the OP or anyone else no if I still want to do this (square setup) should I add the camber plates and m3 control arms? It did not work with the stock suspension and 10mm spacer.
Hi,
With my setup (fully detailed in the top post), it was extremely close, but no rub (and no rolled fenders).
See the section "Clearance" above for more info.
Then later (post #8), I moved from a 245/35 R18 to a 235/40 R18 tire, and the fronts rubbed the back of the oil cooler vents (tires were that bit taller).
Karl.
      05-08-2018, 08:18 PM   #19
500AF
Drives: 2013 135
Hi,
Karl.
Thats what I am going to do but I think to pull it off you must get the camber plates and m control arms you have listed.
Did you get the oem bmw control arms or the trw ones?
      05-09-2018, 07:09 AM   #20
wjk_glynn
wjk_glynn's Avatar
167
TRW
      06-24-2020, 03:40 PM   #21
Alexxv
reviving thread from the dead... I just got a square setup pf 261M style wheels and doing the same I was thinking 255/35 square setup... look like 10mm is the magic number for spacing the wheel... any other tips?
Car is on stock suspension so might add a little bit of camber with eh free trick camber mod...
      06-24-2020, 03:58 PM   #22
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
I use a 12MM Spacer. But I also have coilovers, camber plates, M Arms, and have the fender to bumper connection shaved down quite a bit.
