04-16-2015, 10:54 PM | #1 |
Rep 917
Demonstration of how much tire sizes can very
You'll sometimes see people say that a tire runs wide. Well, what does that mean? Most of us want to know what the widest tire is that we can fit without rubbing. You can't look only at the number embossed on the side of the tire. Manufacturers must have almost no oversight in the specifications they publish for their tires. Kind of scary. I took this picture the day my new tires got mounted. The tread width as listed on the Federal Web site is 9.3in. for a 255x35 18. Tirerack.com has the tread width of the 255x35 18 Continental ExtremeContact DW listed as 9.5in. See anything wrong there?
Left: 255x35 18 Continental ExtremeContact DW, Right: 255X35 18 Federal 595RS-R
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
04-16-2015, 11:59 PM | #2 |
Rep 4,744
Tires can vary a lot. I run 265/275/35/18 r888 which run as wide as 275/285/35/18 r-s3.
04-17-2015, 03:12 PM | #3 |
Rep 4,531
Basic rule of thumb (and very rough one).
Any high performance street tire (ie RS3, ZII*, Rival, RE71R) add 10mm for comparison length Any R-Comp, add 20mm to equate to a typical street tire |
04-17-2015, 03:29 PM | #4 |
Rep 134
I'm looking at nankang ns2r, if I am planning to get their 235/40/17, would that be really wide? If so I would go with 225 if it'll run as wide as a 235 high performance tire.
04-18-2015, 10:27 AM | #5 |
Rep 403
I wonder if there's a site that lists actual tire widths by manufacturer/model/size?
I haven't come across one... Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
04-25-2015, 11:56 AM | #7 |
Rep 4,531
04-25-2015, 12:53 PM | #8 |
Rep 4,040
Drives: 130i coupé ;)
How does this compare to the Dunlop ZI star spec or the new ZII star spec. They get high praise and were a typical more serious street tire to the PSS
04-25-2015, 03:29 PM | #9 |
Rep 566
04-25-2015, 06:28 PM | #10 | ||
Rep 4,531
Mine should be here within a couple weeks. Im going to try and do a comparison against my RS3v2s |
04-27-2015, 08:35 AM | #11 |
Moderator
369
Rep 4,745
Are both of those tires mounted on wheels?
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
04-28-2015, 10:03 AM | #15 |
Moderator
369
Rep 4,745
I'll rephrase the question : In the photo above, are both tires currently mounted on wheels and are those wheels the same size?
05-07-2015, 10:11 AM | #16 |
Rep 917
The Continental's on the left were mounted on 9.5in wheels. The Federal's were not mounted at all.
