      09-01-2011, 08:32 AM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
Cp-e Bmw 135i / 335i Blowoff Valve Kit
ORDER LINK - $549.00
http://www.n54tuning.com/index.php?_...d&productId=92
Replacing the flimsy plastic charge pipe and diverter valve system not only helps you safely hold more boost but also removes a common failure point and flow restriction all in one move. cp-e's BOV kit includes a high quality Tial Sport valve. The adapter features a unique throttle body fitting that is machined of 6061 T6 aluminum and seals against the throttle body using the stock o-ring gasket. The Tial Sport blow off valve is a perfect match for the BMW, its sleek and sophisticated just like the car itself. It offers a sound that is not obnoxious but loud enough that you know something is under the hood.
This Kit features a 2.5" OD mandrel bent 6061 aluminum pipe and a billet 6061 aluminum MAP sensor mount to accommodate the stock MAP sensor. cp-e™ also provides vacuum caps to cover the stock blow off valve nipples. The cp-e™ blow off valve adapter is machined out of billet 6061-T6 Aluminum and uses an advanced 3D machining processes to ensure perfect fitment and long life. The kit is completely removable without a trace.
For those of you who use methanol injection or may want to use methanol injection some day the kit includes a preinstalled bung ready to receive your 1/8" NPT nozzle like the CM10 we include with all of our methanol kits. Just remove the included cap to install your nozzle and you're off and running.
Since the kit uses all OEM style hardware it installs as easily as your OEM pipe with no cutting or relocating of parts as is common place with other kits. Install and removal takes only minutes. This is simply the highest quality BOV kit you can buy for your N54 motor.
      09-12-2011, 02:05 PM   #2
Mike@N54Tuning.com
In stock and ready to ship @ www.n54tuning.com
Mike
      09-12-2011, 03:14 PM   #3
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Link doesn't work
      09-13-2011, 11:07 AM   #4
Mike@N54Tuning.com
Originally Posted by RimasRS View Post
Link doesn't work
It does for me??
Mike
      09-23-2011, 11:11 AM   #5
Mike@N54Tuning.com
Mike
      09-28-2011, 07:07 PM   #6
Mike@N54Tuning.com
Bump for a great deal
Mike
      10-19-2011, 12:36 PM   #7
Mike@N54Tuning.com
Mike
      06-08-2012, 12:58 PM   #8
My135
Drives:
Does it fit with Injen intake?
      06-08-2012, 11:40 PM   #9
milehigh135i
Drives: 2010 135i
bought this used and it sounds great! car drives smoother and the fit is perfect
