12-20-2013, 07:02 PM | #1 |
Rep 324
Drives: 2018 M2 Black Shadow Edition
Vibration when upshifting?
When I rev up to roughly 5000rpm and up shift (paddle shifters) in 2nd - 4th gears, there is a quick vibration. It's annoying.
My first though was a heat shield or something. Any ideas?
12-20-2013, 08:25 PM | #2 |
Proud AARP member in good standing
Rep 635
Is it repeatable every time?
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
12-20-2013, 09:15 PM | #3 |
Rep 324
12-21-2013, 09:55 AM | #4 | |
Rep 454
I cannot pinpoint where the buzzing is coming from and it only last for 1 or 2 seconds until I shift. Sometimes it sounds like it's behind me and other times it sounds like it's in front of me and near the passenger side. I have not attempted to get someone else in the car to help me nail it down yet, mostly because I just haven't had the chance. For me, it's happened since mile 1 of the new car. I attribute it to the PE causing it at certain frequencies or something like that, but I don't know for certain.
2013 Jet Black 135is | 6MT | Coupe | #381/586
12-21-2013, 03:03 PM | #5 | |
Rep 324
12-21-2013, 05:19 PM | #6 |
but no flokka
523
Rep 717
my PE like... pops and gurgles a little bit when i upshift... but thats about it. Sounds really good actually (Manual)
12-21-2013, 05:40 PM | #7 |
Rep 22,992
I have a PE on my manual 135i and it doesn't make this kind of rattle. Only nice popping and gurgling type sounds.
OP - since you can repeat the noise... just show it to your SA or better yet the tech who will be working on your car. I am sure they could find the cause since you can repeat the noise. I would look under your car at the exhaust. It might be something as simple as a stretched or broken exhaust hanger. I would also look at the exhaust for any shinny marks where it could be making contact with the body of the car. The rear X-brace would be my best guess where it could contact the car's body/chassis. The clamps that join the y-pipe to the mids could also be loose. Tighten them to 45Nm. DIY installing N55 mid pipes on a N54... http://www.1addicts.com/forums/showt...=797160&page=5 You might also check the engine tray. There is a heat shield built into it that comes awfully close to down pipes/cats. You could be making contact here - especially if someone botched reinstalling the under tray after an oil change. Dack
