12-14-2009, 06:28 PM | #1 |
Rep 509
New HPFP information from BMW
I just got back from having HPFP #2 replaced. Apparently BMW is now telling its dealers to go through a break-in procedure on the pump. My SA described this to me as driving around 2100 RPM in a high gear with no boost. I'm not sure of the mileage they have to do this for, but between the break-in and tests they ran on my car, they put on about 40 miles. Apparently BMW is concerned that techs are testing out new HPFPs by taking the car full throttle and that this is causing pump failures. Reading between the lines suggests BMW still has no idea why these pump failures are happening, but that's me editorializing.
12-14-2009, 06:33 PM | #2 |
エアーマンが倒せない
271
Rep 2,041
Interesting...also, is anyone else noticing inconsistent power? Sometimes, you'll drive your car, say shift into second and smash down on the gas pedal and feel like WHOA! Other times, you shift into second, smash on the gas pedal, and feel like, "Is this a Civic?"
12-14-2009, 06:44 PM | #3 | |
Rep 815
That is what a tune is for... But yes, I do feel a slight difference from now to then. |
12-14-2009, 06:45 PM | #4 |
Rep 395
12-14-2009, 06:47 PM | #5 |
Rep 509
12-14-2009, 06:48 PM | #6 |
Rep 2,199
they work at full pressure from the second they start, they have to
however they dont flow much fuel until the rpm's are up
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten.. 1974 2002, many various 3s. |
12-14-2009, 06:58 PM | #7 |
Rep 25
Hi. just copy what i wrote inside an other post.
Sorry for my english..i'm french it's funny cause i spoke with one of my collegue about the HPFP problem that BMW have with the N54 & he smile at me..and start to laught! and said to me without telling him any of the symptom..long crank starting!!! he said without hesitation...LOL i discover that before working with us he was working for Lotus & before that with Bosch company. They supply many fuel pump for many car brand. he told me that he worked especially on the same problem (Arizona GM facilities ground) for the CTS, the HHR??, Sky & Soltice duo..One of the main problem about this problem is the temp inside the engine bay, specially when the car engine is stop & re-start after 10 min after a hard session of driving. the temp get so hot under the hood that the fuel start to boil, vaporise inside the pump... now try to pump that..what's killing the pump litte by little it's the starting he said. after that, you have the problem of lubrication, the pump cannot be lubricate properly with fuel vapor. he said to me that BMW will never find a solution about this problem. he said also that he's sure that us here in Canada, there not to much problem about that cause the ambiant temps is colder in any season than you guy from state. Maybe is wrong, maybe not.. i'm just relate is statement and i'm not an expert. After that he show me a lot of picture with elise, Exige and even the Evora that he did all engine test,calibration on. locky baster!!! Just want to share this with you |
12-14-2009, 07:01 PM | #8 | |
Rep 329
12-14-2009, 07:04 PM | #9 |
Rep 67
Great info! I've went through two pumps in 6000 miles, my car is less than 5 months old. I do alot of stop and go driving. I'm sure my under the hood temps are up there. So now the questions is how to keep the under the hood temps down...
12-14-2009, 07:29 PM | #11 |
Rep 1,489
M3 like vented hood? Wrap the whole fuel line(s) under the hood before HPFP and after with that foil stuff. Add a fuel cooler under the intake near the HPFP, M3 like vents on the fenders................umm
-Diplomacy is saying, "nice doggie while trying to find a rock"-
07-Z4 coupe-Black/Black/6MT/sport/premium/X 04-M3 vert-Black/Imolla/6MT/Cold/Xenon/HK/ 06-M3 Coupe-Mystic/Black/6MT/ZCP/Xenon/HK/ 09-135i- AW/Bk-Lette/6MT/M-pac/Nav/Hi-Fi/Usb-Ipod/SOLD |
12-14-2009, 07:33 PM | #12 |
Rep 817
There are two pumps. One in the tank to pressurize the system and one in the engine bay to boost the pressure to the fuel rails. Thanks for the info SCS!
Gone: 2008 135i/2006 330i Arrived: 2006 997/Black/Sand Beige Leather/6MT/Sports Chrono Plus/19" Vorsteiner V-308s/Factory Nav/Sports Steering Wheel/Contrasting Mats/Heated Seats/Bose /V1/iPod adapter/Parrot Bluetooth/50% all around/Black "911" script/"Gundo Hack"/AWE black chrome tips/H&R adjustable front and rear sways/Rennline shift knob |
12-14-2009, 07:35 PM | #13 | |
Rep 324
http://en.wikipedia.org/wiki/Cavitation I think the only way to solve this is to add an upstream pump to boost pressure prior to HPFP, kind of a LPFP. If one exists in the fuel tank already, then crank it up a bit. Last edited by DarthColin; 12-14-2009 at 07:37 PM.. Reason: added text |
12-14-2009, 07:40 PM | #14 |
Rep 329
12-14-2009, 08:10 PM | #17 |
Rep 509
12-14-2009, 08:22 PM | #18 |
Rep 1,035
12-14-2009, 08:33 PM | #19 |
Rep 5,970
12-14-2009, 08:36 PM | #20 | |
Rep 5,970
Cavitation is certainly bad for the pump, but I don't see how it could happen on a pump that has a pressurized inlet like the HPFP on the N54 does. Cavitation usually happens when you starve a pump by trying to pull more fluid than the inlet can supply. If the issues really are being caused by cavitation, it's likely the low pressure pump that's the actual problem, or the software controlling the two. |
12-14-2009, 08:45 PM | #21 |
Rep 231
Has anyone compiled a summary of how many members have gone through 2 pumps already? Knock on wood, I'm at 13K miles and my first still fires up right away.
Question then is - are those that are blowing through 2 in 10K driving harder than the rest of us? Does that make me a 135i gentle-handler? I want to keep the HPFP....but I don't want to be a nanny driver - oh the dilemnas. |
12-14-2009, 08:47 PM | #22 |
Rep 1,288
I don't do much (if any) start-stop driving and mine failed on very cold start after sitting for at least 15-20 hours... Granted the damage from boiling gas could have already been done... *shrug*
i wanted a vented hood anyway.. Now maybe I can convince the wife its a must-have... LOL |
