07-08-2013, 07:00 PM | #1 |
Rep 3,856
How to remove the dashboard vents
Does anyone know how to remove the dash vents on a 1 series? I'm talking the left, middle, and right vents. I heard someone say that for at least the left and right vents you need to pry them up from the bottom, but I tried this and felt like I was putting way to much stress on the parts and I thought for sure I would break something if I continued. I'm doing this because the vents got faded (somehow, previous owner not me) and I have the replacements, just don't know how to remove the old ones. Maybe the entire dash needs to come off? I'm not sure.
Thanks |
07-08-2013, 07:22 PM | #2 |
Rep 4,744
I know the left and right vents by the pilars pull out. i had to do it when installing my P3 gauge. They come out easy.
07-08-2013, 07:52 PM | #4 |
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
http://www.p3cars.com/content/pdf/e8x-car.pdf
There are 2 tabs on the inside which have to be pushed before the left and right vents can be slide out. Not too sure about the centre though. Good luck, they were a bitch for me.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
07-08-2013, 08:01 PM | #5 |
Rep 1,293
^ Didn't notice any release tabs on the center vent. Should be pretty easy with the proper tools. There's a post on installing the optional dash board tray that has pictures (or a video) that shows how it is done. I'll try to find it.
Okay here it is... http://www.1addicts.com/forums/showt...+board+storage It looks like this guy pryed it down from the top, but I swear that I started at the bottom since I had better leverage. At least this gives you an idea of the type and number of tabs you are dealing with. Last edited by Pig Farmer; 07-08-2013 at 08:08 PM.. |
07-09-2013, 07:15 AM | #7 |
The Only Sane One Here
61
Rep 1,135
Pressing the 2 tabs on the side makes it easier, but you can remove them without doing that - just pry from the bottom, and they'll release. I've done it several times.
2011 135i VERT SGM/SB/MOONLIGHT - ED - with every single friggin' option they offered.
07-09-2013, 05:36 PM | #8 |
Rep 3,856
Ahh got them all done and installed! thank you!
03-24-2016, 12:43 PM | #9 |
Rep 382
04-24-2016, 10:28 PM | #10 |
Rep 381
They fade very fast regardless of what we do. If we replace them with the OEM they will fade too, so what did you do?
2013 BMW X1 * 1973 Clubman GT * 2016 Mazda MX5 * 2000 Honda S2000 2004 BMW 325i Touring * 2009 BMW X5 3.0xdrive |
04-25-2016, 12:56 AM | #11 |
Rep 627
Never had any issues with mine and I have a cabrio which sees a lot sun, how you protecting them? I throw on some 303 every month or so and if I know I'm going to be leaving it in the sun a long time I use a sun shade.
04-25-2016, 09:37 PM | #12 |
Rep 3,856
Well I replaced them. It's over 2 years later and they still look good. The fading is just starting to come back and that is with scattered applications of Meguiars vinyl/rubber protectant.
04-27-2016, 05:55 PM | #13 |
Rep 381
I always use a sun shade mine were replaced by the dealer before the warranty expired and now they look the same as before. I was thinking of painting them. Anyway I'll take pictures of mine later, thanks
04-29-2016, 10:29 PM | #15 |
Rep 3,856
06-17-2016, 01:19 PM | #17 |
Rep 99
Anyone painted the vents?
I see mine are fading.... The trim of my convertible is the same as my previous car and I did some painting on the old car (you see the flip cell?...hahahah) , but want to keep the BMW classy too. Would like to see pics before doing something like this.
Used to own the eclipse (avatar pix).
Sold it and post it in memory |
06-22-2016, 11:39 PM | #18 | |
Rep 1,310
for the A/C CENTER VENTS pry out from the top side with trim tools be careful not to pull the vent with your hand right away or else you will snap the wires from DTC and hazard button . use trim tool to remove the buttons
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
06-23-2016, 06:47 AM | #19 |
Rep 324
Here is a tread where someone used Mother's Back-to-Black to solve the problem.
http://www.1addicts.com/forums/showthread.php?t=988737 |
