03-12-2019, 06:34 PM | #1 |
Rep 6,285
FS Brembo Monobloc 6 Piston Calipers for 1M $SOLD$
Hey guys I've waited 3 months for these calipers to arrive, and I've changed my mind on the brembo logo design....
Rather then refinishing them figured I'd list them and see if there's a local buyer keen to snap these up at reduced prices (today's price will be closer to $3k) and then buy another set and get them done how I want them instead. These have been custom powdercoated to match the F8X ///M caliper colour (so the OEM rear F8X ///M calipers will match these). On a 1M the F8x ///M rear calipers bolt straight up, and you can use these front calipers with teh 380mm F8X ///M rotor, or simply stick to OEM 360mm ///M rotor and stock rear calipers/rotors. These are brand new calipers with mounts to suit 360mm E9X 1M rotor or F8X gen 380mm front rotor, pad mounting clips etc, and braided brake lines. These utilise bleed nipple caps and are of course street legal. They're a massive caliper but are lighter than OEM (these are 3.3kg oem is 5.4 kg) and utilise pads much larger than OEM with much larger surface area and thus increased braking performance. These calipers also utilise slide pins for securing the brake pads, so changing pads is a 5 minute job and isn't as cumbersome as the OEM pads and a 380mm F8X rotor and these calipers can squeeze under a 18" rim! No pads are included I can help you select pads depending on what rotor you wish to run. Happy to post Australia wide at your expense and responsibility Price: $SOLD$ Location: Newcastle NSW Last edited by DR-JEKL; 06-18-2019 at 05:29 PM.. |
04-16-2019, 04:54 PM | #2 |
Rep 6,285
hey guys still available, Ive had a few offers (not negotiable unfortunately) and a few guys flake out when it came to sending me their $ for them...
These are much lighter than the boat anchor stock calipers with much larger pads, which are a cinch to replace pads on for track days and then you can swap in oem pads after your track day is done |
05-10-2019, 04:16 AM | #5 |
Rep 6,285
05-28-2019, 09:50 PM | #7 |
Rep 6,285
Yes they are, Ive had a heap of offers but I'm firm on price.
Yes they will work on the M2 with 380mm rotors Here are a few updated pics: https://f87.bimmerpost.com/forums/sh...76&postcount=9 Let me know if you're interested I'll give you my contact details for any questions you may have. Cheers |
06-13-2019, 08:04 PM | #8 |
Rep 6,285
I've had multiple parties interested but havent landed a buyer.
I can offer the following total front axle package: Brembo 6 pot monobloc calipers Braided brake lines TRW cotec brake pads (street style pads) can offer Ferrodo DS2500 for $400 more OEM F8X ///M 380mm rotors (all aforementioned parts are new) Price $SOLD$ with TRW pads or $SOLD$ with Ferodo DS2500's. For comparison a 380mm Brembo GT kit will cost you around $7000 ish AUD with taxes https://www.ebay.com.au/itm/Brembo-F....c100903.m5276 Last edited by DR-JEKL; 06-18-2019 at 05:29 PM.. |
