      01-18-2024, 10:42 AM   #1
Blau
J
Blau's Avatar
Drives: BMW 128i
2011 BMW 128i  [6.00]
2013 BMW X3 28i  [0.00]
135i short shifter on a 128i?
I'm looking to see if there is a way to make a 135i short shifter work on my 128i swap. It seems like it should work, but I can't find much info on it and I do see that after market short shift kits usually only list the 135i.
Any help will be greatly appreciated.
      01-18-2024, 06:41 PM   #2
spidertri
spidertri's Avatar
Drives: 11 128i 6MT Sport
2011 BMW 128i  [0.00]
I've been using a 135i N54 shift lever on my car for several years now with no issues, it shortened the throw a good bit from the stock 128i lever.
What parts come with the short shift kit you're considering?
The main difference I can think of is that the shift selector rod for the 128 has a bend in it where the 135i doesn't. But your kit may not include that part, some kits do and some don't.
11 128i slicktop
13 WK2
19 Alltrack S
      01-18-2024, 07:29 PM   #3
Blau
J
Blau's Avatar
Drives: BMW 128i
Did your kit come with the SSR? I have a kit attached to an n54 trans I picked up. Can't tell the brand, but the whole thing is intact. I also have the stock n52 SSR attached to a stock shifter. Maybe I can piece meal this kit.
      01-19-2024, 06:05 AM   #4
spidertri
spidertri's Avatar
No, mine wasn't a kit, I was just refreshing all the rubber parts in the stock shift linkage and used the 135i N54 factory part since it's a shorter throw than the stock 128 lever.
My SSR is still the stock 128 piece. Although I wouldn't mind eventually getting a dssr.
11 128i slicktop
13 WK2
19 Alltrack S
Blau374.00
      01-19-2024, 06:25 AM   #5
Blau
J
Blau's Avatar
Drives: BMW 128i
This is exactly the info I needed. Thank you.
