      06-17-2014, 01:07 AM   #1
thezone135i
thezone135i's Avatar
Drives: Volvo S60 R-Design Polestar
2008 BMW 135i  [0.00]
2012 BMW 535i  [0.00]
Spacers on 135i Oem wheels - Thoughts?
Hey guys, I like the stock M double-spoke style rims on my 135i but they could be a little more aggressive offset wise especially in the front. I was wondering if going say 12mm front and 8mm rear would upset the suspension geometry dialed in from factory. Or would it be better to go same front and back say 10mm? I'm not looking for a really aggressive look just closer to flush and I don't want to fork out for wheels as stated I quite like the factory wheels.
Cheers
      06-17-2014, 02:40 AM   #2
froop
froop's Avatar
Drives: 08 AW 6MT E82
We've got 15mm spacers on the front and 12mm spacers on the E88 and I feel like it helps the handling quite significantly. Looks much better too. No rubbing and drives fine. Stock suspension and wheels with 215/245s
      06-17-2014, 06:45 AM   #3
thezone135i
So you're running 15 on the front? Obviously this reduces the stagger which I can imagine looks better but that seems like a lot for the fronts. I'm reading all sorts of negative things about positive scrub radius when going too wide on the front.
      06-17-2014, 06:48 AM   #4
froop
froop's Avatar
Yep 15 on the front is fine. Stock wheels, stock tyres, stock suspension and no rolling. No rubbing on either the front or back.
It's pretty flush but I'm sure you'd be happy with 12 and 8.
      06-17-2014, 07:13 AM   #5
thezone135i
Cheers froop. Do you have any pics?
      06-17-2014, 07:48 AM   #6
Chandon
Chandon's Avatar
Drives: 1M
I've got 10mm all round on my car with stock wheels 225/255 tyres. Rears were rubbing before so I've got the rears rolled, fronts are pretty flush.. Rubs VERY minor only when I'm getting up my driveway.
Probably the most relevant picture I've got:
      06-17-2014, 05:16 PM   #7
thezone135i
Is that stock ride height?
      06-17-2014, 05:45 PM   #8
froop
froop's Avatar
Here are some photos that I just took for you. The spacers were courtesy of @UR25IO. He ran with them as well but on lowered suspension. He had the rears rolled but I'm not too sure if that was because it was rubbing. He has an E82 though.
E88's tend to sit a little lower due to using the same springs but with heavier weight.
As you can see, it doesn't really get much more flush than that without poking.
      06-17-2014, 06:00 PM   #9
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
162
Drives: E92 M3 2012 Edition 500
If you must use spacers remember to replace the wheel bolts for a longer series.
And check the bolt tension with a torque wrench often as they can work loose.
I am not a spacer fan, but sometimes it is a must.
      06-17-2014, 06:23 PM   #10
UR25IO
UR25IO's Avatar
Drives: 2011 BMW 135i M-SPORT DCT
The front is perfectly fine with stock wheels ,tyres (215/40/18) and suspension. Only when you go to a 225/40/18 the tyres will only rub on the clip that holds the front bar to the front quarter pannel.
At the time I had the BMW performance springs installed.That was lowerd - gap between tyres and arch was about 10mm clearence - no rubbing with 215/40/18 stock tyres but did rub on the clip with 225/40/18 P-ZERO.
My rear guards had to be rolled making clearence for the BMW PS when installed, other wise it would fold your rear guards. After when rolled it may slightly rub on 10 o'clock inside. That is over a big bump or hump at speed.
Going to coilover-you would not have any of these rubbing problem due the suspension being much stiffer as I have experience.
      06-17-2014, 10:21 PM   #11
thezone135i
Cheers for the input guys, froop that looks great, perfectly flush. I just wonder if BMW used a staggered set up for a reason. Im thinking i might go 10 or 12 all round to at least keep the staggered set up.
      06-18-2014, 05:23 AM   #12
froop
froop's Avatar
Staggered setups I believe are usually to keep the car's behaviors more understeery, especially for a powerful rear wheel drive car. This is supposed to be safer than a tail happy rear wheel drive car.
Of course once you significantly up the power, no amount of extra rear rubber over the front helps lol.
A lot of regular trackers go for a square setup to make the car more neutrally balanced.
      06-18-2014, 07:17 PM   #13
Stuart@BMRAutowerkes
Stuart@BMRAutowerkes's Avatar
808
Drives: a black car
Don't use 8mm spacers as your wheels will no longer be hub centric.
5, 10, 12, 15, 18 etc are all fine.. but 8mm means your wheels will no longer sit on the hub.
      06-19-2014, 07:39 AM   #14
thezone135i
Hmmm..... I used H&R hubcentric 8mm on the front my B7 A4 and they were a perfect fit. But I notice there is no listing for 8mm for the 135i on ecs. Oh well.
      06-19-2014, 08:57 PM   #15
Nugget
Nugget's Avatar
650
2011 BMW 135i  [10.00]
The hub lip on 135i is 10 or 11mm.
So a 5mm spacer is just a slip on but leaves a lip of about 6mm, that's the biggest slip on I would run.
Then you need to step up to at least 10mm to get a hubcentric one.
      06-20-2014, 05:42 AM   #16
thezone135i
Consider very light weight Verstrabe spacers https://www.sonicms.net/index.php?ro...product_id=443
Certainly looks like a good idea but when I read the website I feel like im buying a network marketing gimmick:
Machined out of T6061-T6 aircarft grade aluminum
surgical grade precision tolerances
Motorsport inspired pentagon shaped design
Anodized in a matte gunmetal finish for additional strength
Sorry for being a cynical f&$k but its sounds like wank.
      06-20-2014, 08:14 PM   #17
ansch
Drives: SGM 135i
had a set of BMS 12mm spacers on for a while and didn't really like the feel of it. Made it feel a bit too soft sprung. It looked good though
      06-21-2014, 02:55 AM   #18
thezone135i
Interesting, how do you mean soft sprung? I had a set on my A4 Quattro and the only issue i had was the fronts seemed to track the grooves in the road more which made the front feel a little more skittish. But the same thing can happen when you go to a bigger wheel as well.
      06-22-2014, 09:05 PM   #19
ansch
Drives: SGM 135i
Yes it does seem to tramline a lot more too. I think the "softer" feeling comes from the extended lever effect by the spacers. Never had low offset wheels fitted so can't comment if it feels the same. Although usually with wheels you'd normally go wider as well.
      06-28-2014, 09:46 PM   #20
thezone135i
Hey guys Im a bit confused,
I notice on the ecs website that for H&R spacers they recommend using 40mm extended bolts with 10mm spacers http://www.ecstuning.com/BMW-E82-135...Spacers/ES249/ and 43mm bolts with 12mm spacers http://www.ecstuning.com/BMW-E82-135...Spacers/ES252/.
But for ecs brand spacers they recommend 35mm bolts for 10mm spacers http://www.ecstuning.com/BMW-E82-135...acers/ES11297/ and 39mm bolts for 12.5mm spacers http://www.ecstuning.com/BMW-E82-135...acers/ES11298/ WTF?
I thought the oem bolt size was 26mm? this would make 36mm and 38mm?
Anyone know why the difference?
Cheers
      07-28-2019, 09:29 PM   #21
fate_f30
fate_f30's Avatar
Drives: 2014 Glacier Silver F30 328i
Hope you're still on here but here goes nothing... I was wondering if you could help. I have an e88 and I'm getting a ridiculous amount of rubbing in the front when I hit bumps. I recently changed out my suspension to Eibach Springs 0.8 F / 0.5 R, Koni Yellows, and front M3 Control arms. I'm currently not running camber plates as we felt we didn't need too and I also have 15mm spacers all around. We did an alignment and the car is dead straight but I currently have quite a front end shimmer at highway speeds. Not sure what would be causing this? I'm still on stock wheels and plan on keeping them for awhile. Any suggestions? Tips or tricks? Thanks.
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
      06-12-2020, 11:26 AM   #22
jsciam
jsciam's Avatar
21
Drives: 2006 Interlagos ZCP 6MT M3
I'd almost guarantee it's unbalanced wheels. Once I dropped mine on the same kit I had to re-balance my wheels coincidentally.
