      02-08-2013, 10:05 PM   #1
fe1rx
Drives: 135i, 328i, Cayman S
Ground Control Street Camber Plate "Pointers"
As most of you will know, the strut towers have slotted holes to allow for some camber adjustment if the alignment pin is removed from the OE upper strut mount. The alignment pin centers the mount in the slots, meaning that by removing the pin you can get approximately ±0.25 degrees of adjustment from the stock -0.5 degrees.
Name:  1 OE Strut Mount.jpg
OE Strut Mount with Alignment Pin
Ground Control Street camber plates incorporate a stainless steel pointer plate that allows field adjustment to repeatable values. The only problem is that unless the pointer plate is fixed relative to the strut tower, it is free to move within the ±0.25 degree range permitted by the slots in the strut tower – not good for repeatability.
Name:  2 GC Street Plate.jpg
Ground Control has thought of that, but they don’t provide any installation instructions so you need to figure out their solution on your own. The pointer plates are “handed” and need to be installed chamfered edge up. They incorporate 10-32UNF tapped holes that permit installation of an alignment pin (not supplied) that bias the pointer plates at the inboard limit of the slotted hole in the strut tower. You just need to find a suitable pin.
A fillister head screw would probably work, but my solution was to enlarge the holes to ¼” and to TIG weld in a stainless ¼” socket head cap screw in the correct hole. The weld must be ground flush on the bottom to prevent it gouging the camber plate.
Name:  3 Modified Pointer Plates.jpg
The modified pointer plates bias the plates towards maximum negative camber in the slots.
Name:  4 Modified Pointer Plate Installed.jpg
Pointer Plate biases Camber Plate towards maximum negative camber
With M3 front suspension arms, my front camber is approximately -1.5 degrees with the pointer set to zero on the camber plate.
Name:  5 Camber with plate set to zero.jpg
Camber Plate at zero, M3 Suspension Bits, -1.5° Camber (aprox)
I can adjust the camber plates to a reading of -2 for an actual camber of approximately -3.5 degrees before the upper spring perches (for OE springs) come uncomfortably close to the inside wall of the strut tower.
Name:  6 -2 deg Pointer Setting.jpg
Pointer at -2 degrees
Name:  7 Spring Clearance at -2 deg indicated.jpg
Spring Clearance with pointer at -2 degrees
      02-09-2013, 03:48 AM   #2
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
good stuff
      02-10-2013, 11:38 AM   #3
bluephobic(1)
Inspiring the youth of tommorow...
Drives: AllTheTQ's
2009 135i  [0.00]
I have those :P, GC makes some great parts and they have amazing costumer service no idea why more people dont use there stuff
E82 135i Jet Black over coral red
E39 Dinan 540i manual Topaz blue over beige
F15 X5 35D Mineral white metallic over Mocha Nappa
991.1 911 GT3 Guards red over black alcantara
P13 570GT MSO Volcano Red over saddle tan
      02-10-2013, 11:55 AM   #4
Sarge135
Semper FI!
Sarge135's Avatar
Drives: 2009 135i
Which one would we have to buy to work with ST/KW coilovers? And will this eliminate the need to use the stock upper of the oe strut?
2009 SGM 135i M-Sport
Ark l Blackline l iCarbon l AFE l Hawk l VMR l ST Coilover l Parrot Asteroid l JL Audio l Janus-Design l Reiger l BMW Performance l COBB l Evolution Raceworks l TIAL l VRSF
      02-10-2013, 03:02 PM   #5
fe1rx
This particular plate appears to be best suited to full size springs although the GC website says it is available configured for race springs. Despite the text on the Ground Control website, these plates are not adjustable for caster. They also make a "Hybrid" plate that provides articulation of the spring perch, which would be a better choice for a race spring, in my opinion.
Here is how the "Street" plates work:
The Ground Control Street camber plate uses a large steer bearing and a separate camber bushing. All weight is borne by the steer bearing. The camber bushing allows the strut shaft to articulate and it carries the damping loads. Because the spring perch remains flat relative to the plate and does not articulate with the shaft, this camber plate is best suited to full size OE or Sport lowering springs as opposed to race springs (which are less forgiving of axial misalignment).
Name:  1 Plate on Strut.jpg
Assembled Strut
Name:  2 Plate with Bushing and Upper Steer Bearing Race.jpg
Camber Plate and Upper Steer Bearing Race. Slots allow camber adjustment only.
Name:  3 Steer Bearing.jpg
Spring Perch with Steer Bearing
Name:  4 Spring Perch.jpg
Spring Perch
Name:  5 Bare Plate.jpg
Bare Plate
Name:  6 Camber Bushing Set.jpg
Camber Bushing Parts
Name:  7 Camber Bushing Set Assembled.jpg
Camber Bushing Assembled
Name:  8 Upper Mounting Bolts.jpg
It is necessary to trim one of the upper mounting bolts to clear the strut brace
      04-24-2015, 07:51 AM   #6
katsooba
katsooba's Avatar
85
Drives: bmw 135i
this info is awesome, dont know why there isn't more discussion on this subject,
as to how fits what and such
135i N55 / KW V3 / MHD Flash / Tons of grip mods / CP-E charge pipe / CP-E 7" FMIC
      04-25-2015, 09:37 PM   #7
_Ryan_
Drives: E87 130i
2005 BMW 130i  [5.24]
A few things stand out to me:
- Why do they mark numbers on the plate?
- Why don't they fit the pins (or offer them)?
- Have you tried the 1M strut brace ends? They also locate the studs and top plates in a consistent manner, whilst providing better access to the strut top.
      04-25-2015, 10:30 PM   #8
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
The 1M strut braces do not locate anything. They are located by the studs in the "guide support" (or the camber plate, or whatever one is using) with their position subject to the stock slotting of the chassis absent the aforementioned alignment pins. They do provide excellent access to the strut tops, though.
      04-26-2015, 05:12 AM   #9
_Ryan_
Drives: E87 130i
Interesting, so you're suggesting that a closed ring of a mounted part (assuming the firewall end of the brace is torqued to spec) does in fact have movement?
      04-26-2015, 08:18 AM   #10
Suprgnat
Слава Украине!
Suprgnat's Avatar
Ukraine
2317
2013 128i  [9.58]
You're right, and I'll qualify my statement.
During the initial assembly of the front suspension the brace assembly would have to be loose to do the alignment and get a consistent zero point for both sides as the braces have no means to locate the strut tops.
Once aligned and torqued, the 1M/M3 braces should be rigid enough to hold things in place while loosening the strut nuts for track side adjustments of the GC camber plates.
      04-26-2015, 08:23 AM   #11
_Ryan_
Drives: E87 130i
Thank you, that's how my Vorshlags are setup.
TL;DR
The caveat when using the 1M/M3 brace is that the firewall brace position shouldn't vary between alignments if you rely on assumptions for accurate track side alignments; that said, if you don't have access to the tools or a friendly to weld on pins as per the original post, this may be a viable work around for ~$200 which you can fit yourself with the added benefits of better strut top access.
      12-23-2015, 08:17 PM   #12
davidwarren
davidwarren's Avatar
187
Drives: 328,325, 325, 335, X5, 640 GC
I am so glad I found this. I have GC street plates on my e90. I have been looking for a way to keep the marker plate stationary so only the adjustable part moves.
Looks like I just need to find an appropriate 10-32 screw.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
alignment pin, camber plates, ground control
