08-21-2014, 12:40 PM | #1 |
Rep 581
Brake Boosting?
I have been told many cars can not brake boost. I have tried it in my 135i but the boost doesn't seem to build.. Only the rpms.
This would be most beneficial for 50mph pulls where we are at 3k rpms. Looking for some info on this. Doesn't seem to be discussed much on here. Note: For 6spd manuals.
08' Sparkling Graphite Metallic E82 135i. 6spd Manual. |
08-21-2014, 01:31 PM | #2 |
Joint Chiefs of Staff
24174
Rep 190,750
Brake boosting will put a lot of pressure on your car.
It is not recommended to be used often. Only use it if you are at the track and every ms is important.
08-21-2014, 03:14 PM | #3 |
Rep 581
I'm aware it's not for the faint of heart I am just asking if our cars are able to do it.
08-26-2014, 02:01 PM | #4 |
Rep 3,856
08-26-2014, 02:36 PM | #5 | |
Rep 513
full bolt on 6mt
cobb e30 protune fortune auto coilovers 12.08 119 |
08-26-2014, 03:19 PM | #6 |
Rep 111
You can, and boost does build (verified via cobb Ap). I do it often, though I'm aware it can lead to major issues. I will admit that it does not work quite the same as it did with my TT Z32, but then tech in that car is prehistoric compared to our cars. Boost shoots up fast so be aware and practice your timing it during your rolls.
08-27-2014, 02:19 PM | #8 |
The Crowing
111
Rep 2,005
I would think drag strip would really start to wear or heat up the clutch? I thought brake boosting was for the roll? Maybe auto it's easier to do it in?
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
08-27-2014, 08:49 PM | #9 |
Rep 3,856
08-28-2014, 12:07 PM | #10 | |
Bashar
412
Rep 1,120
