10-15-2014, 02:26 PM | #1 |
Rep 157
Easiest way to cause a check engine light?
My car has misfired a few times without throwing a check engine light and I just want to verify that my jb4 is not hiding all CEL's. I'm pretty sure I have this functionality turned off, but the newer documentation doesn't list the options to do it.
What is the easiest way to cause a check engine light without harming anything? On my old evo I know you could just disconnect the CPS and try to start it and it would throw one. |
10-15-2014, 02:54 PM | #2 |
Rep 22,992
Leave the gas cap off and start the car. That will throw the ECL on. After a few hundred miles(or ignition key cycles) it should go out.
10-15-2014, 02:59 PM | #3 |
Rep 157
10-21-2014, 05:18 PM | #4 |
Rep 157
Leaving the gas cap off and starting the car didn't cause a check engine light. Is there anything else I can do to easily cause one?
Also, the setting I'm using to disable autoclearing is speedo on 1, tach on 4. Is this right? I'm on the latest model of JB4. I'm not sure why the steering wheel control guide doesn't list these options anymore. |
10-21-2014, 05:36 PM | #5 |
Civil Rights Activist
115
Rep 949
You could use some BS gas in the car and dial up some boost and probably get a few detonations.. But then you're stuck with BS gas.
10-21-2014, 05:44 PM | #6 |
Rep 152
leave the gas cap loose. might take a few miles for it to kick in.
leaky gas cap CEL is fairly easy to trigger
2011 BMW 135i, 6MT, Jet Black - BMS Clutch Stop, Berk Street Exhaust, LCI Blackline Tails
2007 Mazda RX8, 6SP, Stormy Blue Mica - Sold |
10-21-2014, 05:49 PM | #7 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
Unplug the MAF. Instant SES light, and its easy to get to.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
10-21-2014, 06:11 PM | #8 |
Rep 952
That. Loosening the gas cap won't do anything. You would have to leave it loose for multiple drive cycles for it to trigger a code.
10-22-2014, 12:36 PM | #9 |
Rep 157
Do I even have a MAF sensor? I was under the impression that the N54's only have MAP's.
Also, I'm definitely not going to trip the CEL by purposely causing knock... |
