      03-15-2014, 08:39 PM   #1
Chunner
Chunner's Avatar
90
Drives: BMW 135is | #341/586
Largest rear tire on stock 135i rim?
For a 135i: What is the largest size tire we can have on our rears with the stock OEM rim and stock M Sport suspension?
Existing rears are 245/35 on 18" x 8.5" Rims
and with that rear larger tires. Can we keep the existing OEM size on the fronts or should they be larger as well?
Existing fronts are 215/40 on 18" x 7.5" Rims
Thanks!
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
      03-15-2014, 10:56 PM   #2
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [5.00]
Send a message via Yahoo to adrean8j
Thanks!
225's in the front and 255's in the rear is the general consensus.
SGM was God's color and has been recalled to heaven.
      03-15-2014, 11:06 PM   #3
Chunner
Chunner's Avatar
90
For a 135i: What is the largest size tire we can have on our front and rears with the stock M Sport suspension?
Are these too large?
Front 245/35 tires on 18x8.5 Rims
Rear 265/35 tires on 18x9.5 Rims
      03-16-2014, 02:38 PM   #4
135Pats
135Pats's Avatar
Drives: A few BMWs
That will fit the wheels no problem
F30 N55 XDrive EBII
      03-16-2014, 03:58 PM   #5
ulrichd
ulrichd's Avatar
Drives: 128i M-Sport
It depends on the wheel offset. 265s can rub in the rear if the wheel offset is too low.
      03-16-2014, 10:02 PM   #6
Chunner
Chunner's Avatar
90
Another question.
Will 265/40 fit on the rear OEM 18" x 8.5" Rims?
Will 255/45 fit on the rear OEM 18" x 8.5" Rims?
and on the front, can I stay with 215/40 on the OEM 18" x 7.5" Rims when using either two above mentioned sizes for the rear?
I am trying to go with the widest tire utilizing the stock rear rims while leaving the front stock set up alone.
THANKS!
      03-16-2014, 10:09 PM   #7
Stohlen
Drives: AW 135i
2008 BMW 135i  [2.83]
I have 245/40s and 285/30s on that rim setup. I would not go bigger than 225/255 on the stock setup.
Build thread: http://www.1addicts.com/forums/showthread.php?t=748935
I will never buy from Forgestar or EAS again after my nightmare wheel purchase.
      03-16-2014, 11:34 PM   #8
ulrichd
ulrichd's Avatar
Another question.
THANKS!
255/45 would be a really tall sidewall tire, would look silly and be much larger circumference than stock.
      03-17-2014, 02:00 AM   #9
PopsnBurbles
Drives: 135is :) 192/586
Sorry to thread jack but I'm curious about the largest tires we can fit with the stock M-sport suspension and possibly BMW Performance Suspension without any rubbing/contact/etc. All stock, no rolling, no spacers, nothing...
The stock wheel specs are:
Front: 18" x 7.5" et 49
Rear: 18" x 8.5" et 52
I'm think 235/40 R18 up front and 265/35 R18 for the rears?
      08-15-2017, 09:44 PM   #10
V8<turbo4
Drives: 2008 Mitsubishi Evo X
Bump would like to know as well
Stock rims stock M suspension
      08-15-2017, 09:57 PM   #11
xQx
If you don't want rubbing issues, it's 225/40r18 on the front, 255/35r18 on the back.
If you're asking what can be fit on the rims, it's 245f/265r - but it's not recommended - (depending on the tire) you're pulling in very hard at the top of the rubber and causing the tire to be more oval shaped than it's supposed to.
Also, you'll probably rub, and at the back there's a gas filler line that you can sever if you rub in the wrong spot (which is incredibly inconvenient next time you go to fill up).
2008 BMW 135i Convertible 6AT (E88 N54) M Sport (BMS DCI, VRSF 7" Intercooler, VRSF CP, VRSF v2 DP, Turbosmart BOV, JB4 w/ Bluetooth Gauges, BMS E85 BEF, SmartTop Module, xHP Stage 3, BMS Cowl Filters, RB Inlets & Outlets, MFactory 1.5way LSD, Fuel-it Stage 2+ Bucketless)
