      10-11-2009, 11:56 AM   #1
PrimoM3
Chemofski
PrimoM3's Avatar
Drives: '13 X5M
Installed OEM e93 front sway bar (28mm)
This upgrade is highly suggested for those wanting to greatly reduce or eliminate the body roll in their 135. I simply couldn't feel any roll when pushing it yesterday in the twisting hills above Portland, but the pessimist in me says it can't be gone completely. Can it? The car stayed nice and flat with a neutral feel. This is how a sport pkg 1 should feel in my opinion.
In addition to the bars, you'll need the e93 brackets and bushings. The bushings are much harder than our stock ones and the brackets seem to be made of aluminum. Install only takes about an hour using basic handtools. I used the DIY from larryn as a guide, but I chose not to remove the wheels and drove the car onto rhino ramps instead of using a jack/stands.
Do it, you won't regret it.
'13 Individual Frozen Brilliant White ///M3 Coupe
Ordered 2/15/12 | Euro Delivery on 9/21/12 | U.S. Redelivery on 12/6/12 | Motor Dead on 7/15/13
'13 Space Gray/Mugello Red X5///M
Pavement Punisher | Snow Muncher | Family and Board Hauler | Roadtripper
      10-11-2009, 01:06 PM   #2
escobar929
escobar929's Avatar
154
Drives: M2 CS
2020 M2 CS  [10.00]
2020 M240i  [0.00]
good stuff bro, i wanna start w/ kw v2 and then see if a sway bar is still needed
roughly what did everything cost?
      10-11-2009, 02:34 PM   #3
PrimoM3
Chemofski
PrimoM3's Avatar
Drives: '13 X5M
Spent $250 for everything. I'm on stock suspension other than the sway with Dunlop Star Spec tires.
      10-12-2009, 05:38 PM   #4
vitig
I have the e93 bar and i very happy.
This mode and the cdv are very good whit a few money.
135ijb3, h & r filter, SSK, CDV,clutch stop, klracing fmic,seccond catted ,225-255 michelin ps3, E93F-E92R swaybars.M3 parts front.M3 tension rear.Plates mod(F-2,0º R-1,5º).Bilstein + stock springs.Ps rotors.Subframe bushings.Weichers fstruut.Finally mods sdiff and raceland dp.
      10-12-2009, 07:16 PM   #5
timhatimay
timhatimay's Avatar
129
Drives: ///M3
2018 BMW M3  [0.00]
2009 135i  [0.00]
Good to hear! I was pining over the decision of which m3 bar to install. I was hoping to dial out the roll, so it sounds like it should be great. I ordered the e93 bar, and now I'm just waiting for an opportunity to install. Can't wait to put it on.
Tim
M3 6MT SmTo/CS ZCP
135i MT JB/CR ///MSport - Gone
      10-12-2009, 07:28 PM   #6
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Drives: Jet Black '08 135i
So how much roll does this actually dial out with just a 1.5mm difference?
Also, I noticed the end links have different part numbers going from the e82 135 to the e93 M3. Did you just re-use your end links?
      10-12-2009, 08:29 PM   #7
arrutled
arrutled's Avatar
104
Drives: Olsa
There is a 19 mm kink in our sway bar
AW 135i w/ blackette, performance short shift kit, BMW alarm, Performance rotors, APEX ARC-8 wheels, Direzza Star Spec 235/275, Dinan stage 3 suspension, M3 wishbones/tension rods/front sway/rear subframe bushings and thats all folks!
      10-12-2009, 08:51 PM   #8
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Trust me you will still want the sway bar. It is the absolute best upgrade bang for buck for the 135i's body roll. I would do the KW's second.
SGM was God's color and has been recalled to heaven.
      10-12-2009, 09:20 PM   #9
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
That I know. Now can you answer my question about how much body roll the new bar dials out? Obviously, that will be a guess-timation but I still would like to hear it.
      10-12-2009, 09:25 PM   #10
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
I would say with the Hotchkis at least 55-65%...don't know about the OEM M3 bar though (arent they very similar?).
      10-13-2009, 08:19 PM   #11
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Any more info for the questions posted above?
      10-13-2009, 08:30 PM   #12
PrimoM3
Chemofski
PrimoM3's Avatar
Drives: '13 X5M
Sorry for the delay... I'd say this dialed out almost all the body roll for me. I know the harder rubber OEM bushings help in addition to the thicker, non-kinked bar. It just feels great now coupled with my performance tires. It doesn feel tall and just squats flat through a turn.
I didn't upgrade anything else aside from the bar, bushings and alum brackets. I plan to buy the other M3 pieces in the spring to add a bit more neg camber.
      10-13-2009, 09:15 PM   #13
arrutled
arrutled's Avatar
104
Drives: Olsa
It is really hard to say. I dont have pictures or anything. I know it feels tighter. When we have our next autocross I hope to jump from car to car and see the difference. I hope your not looking for an exact number, because I doubt the companies that sell these sways could even tell you exactly that. your best way to go is either find someone who has one and take a ride or buy it yourself for 200$.
      10-13-2009, 10:09 PM   #14
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
I understand where you are coming from and I know you cannot assign a number to hence the last sentence of my statement.
I suppose another way to ask this question is if this low-cost option is comparable to the aftermarket bars out there by H&R, Hotchis, etc...?
      10-13-2009, 10:28 PM   #15
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
I think it is pretty much the same exact bar.
      10-14-2009, 06:46 AM   #16
arrutled
arrutled's Avatar
104
Drives: Olsa
ill guestimate somewhere between 25-30% descrease in roll from my 26.5 M3 bar.
      10-14-2009, 04:35 PM   #17
SlickShift
SlickShift's Avatar
Drives: '11 BMW E90 M3 ZCP, '21 X5 ZMP
I just installed a UUC front bar last weekend and the difference it quite noticeable. The car is much more responsive and predictable now. Definitely a must-have!
-Nick
2018 BMW 440i - M Sport, Exec
Glacier Silver Metallic/Coral Red Dakota
Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i
      10-14-2009, 07:50 PM   #18
Muffnbluff
Redline Addict
Muffnbluff's Avatar
21
Drives: '14 BMW 335 xdrive
If I were going to do any suspension work I'd stick with OEM stuff because it sucks to have to grease up those polyurethane aftermarket bushings.
      10-14-2009, 08:36 PM   #19
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
Is the bolded part just a typo or are you running the 26.5mm front bar from an e92 M3? If so, how did that compare to the stock 135 front bar?
      10-14-2009, 08:48 PM   #20
arrutled
arrutled's Avatar
104
Drives: Olsa
That is not a typo. It is the exact same bar, except without a kink. it probably saved them money somehow to have the same width and then induce kinks for the lesser cars than the M3. The bushings that come with it are definetly stiffer and have a locking mechanism, kinda cool.
      10-14-2009, 08:57 PM   #21
MadMan77
↓↓↓ Ex-Con ↓↓↓
MadMan77's Avatar
Guam
34
That is good to hear. So the 28mm e93 bar should be just a bit stiffer than that. This sounds like something I will be ordering when I get back home.
      10-15-2009, 04:55 AM   #22
arrutled
arrutled's Avatar
104
Drives: Olsa
yep, enjoy!
