11-09-2011, 10:47 AM | #1 |
Rep 18
BMW 1M and "LIMP MODE"
Hey guys,
So far I have not heard of any 1M's hitting the dreaded N54 "limp mode" through the various track tests etc. This is despite the stock 335i / 335is or even "BMW Performance Pack" equipped ones hitting limp mode fairly easily after prolonged hard driving. From my understanding, the tuned N54 (especially with piggybacks) hit limp mode MUCH more frequently than when stock, for obvious reasons even when running aftermarket oil coolers / intercoolers / radiators etc. Would any one, tuners included, have any idea why the 1M is more resistant to limp? Could it have something to do with: 1. Cooling Hardware 2. M ECU tuning which perhaps increases the limp thresholds I think it is important for us to ascertain this as it would then greatly impact many individual's decisions whether to tune the ECU or not. We all know that the N54 is capable of running more power without significantly decreasing engine life, but having more power is one thing, Id personally want a car that i can drive hard for prolonged periods without having to worry about triggering limp mode. |
11-09-2011, 11:29 AM | #2 | |
Rep 1,898
11-09-2011, 12:18 PM | #6 |
Rep 2,084
If 1M's are getting limp mode less often than 135i's, one reason could be that there aren't any 1M's with automatic transmissions. If you read the gigantic thread about limp mode at e90post forum, you'll see that most of the cars that are limping frequently have AT. The AT is water-cooled and seems to make a big difference in pushing water temp past the 245F threshold for limp mode. Another reason for less limping in 1M's is that 1M's have stronger radiator fans than 135i's. And as marcel_b mentioned, there appears to be better airflow.
11-09-2011, 12:27 PM | #7 |
Rep 401
Drives: 2011 Saphire Black 1M Coupé
In addition, I'm pretty sure 335i / 135i have isolation on the inside of the hood. A 1M doesn't. Feel how hot the hood gets. I'm waiting for the day, when the paint starts to crack. Imho the M GmbH has simply done everything they could to eliminate a known problem.
The best piece of road - worldwide.
11-09-2011, 12:57 PM | #8 | |
Rep 22,992
Have you seen the new F20's underside of the hood - it has a metal heat shield. I think BMW did this bc the turbo on that 1.6L turbo four sits really close to the hood. Btw... I think only some early 125i's128i's had hood insulation. But later cars did not get the insulation. I remember that bc there was two 1er forum guys at the Ring meeting this summer and they traded out the hood insulation! lol |
11-09-2011, 04:03 PM | #11 |
Rep 11,785
LOL at the ED comment.
No limp mode due to... Additional oil cooler additional radiator DCT trans case is used for 1M 6 speed trans. The DCT transmission case has it's own sump... Thus.. the trans fluid is cooled better in the 1M because the trans fluid uses this sump. Less heat.. no limp mode. There have been no reports of people with Tuned 1Ms experiencing limp mode... leaving the answer to your query with a single possibility.. 1. cooling hardware |
11-09-2011, 07:40 PM | #12 | |
Rep 2,898
Surely the cooling hardware changes are the biggest contributor, but I wouldn't rule out the additional possibility that the ecu programming was revised to increase the temps that trigger limp home mode. Neil Last edited by MDORPHN; 11-10-2011 at 07:55 AM.. Reason: grammar |
11-10-2011, 06:21 AM | #13 |
Rep 2,084
Hey Neil, that yellow indicator we saw on Sunday was limp mode. See I did rtfm.
11-10-2011, 08:34 AM | #16 |
Rep 2,084
No, Neil rode with me in my 135i. I got limp mode, pitted in, shut down for five seconds and restarted. The indicator didn't come back, so we went back out and my car was fine for twenty more minutes on track and two more sessions that day.
The same thing happened once before. I have a water temp gauge, so I could see both times that my oil and water temps were normal and nowhere near limp thresholds. |
05-13-2012, 11:00 AM | #17 | |
Rep 199
Drives: Ford Focus ST: 2.5l /5 cyl
05-13-2012, 11:07 AM | #18 |
Rep 1,479
Drives: 2017 F80 M3
Sorry, but I'm not sure how posting to the 1M forum is going to help with your 135 issues.
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
05-13-2012, 11:11 AM | #19 |
Rep 173
The 1M stays a lot cooler then the 335i I had before. Even on the track (Ring incl. GP-track) it didn't go above 1bout 125 Celsius. My 335 DCT I got up to 148 degrees and Limpmode on the same track.
Next to the hardware (I had the Powerkit on my 335 which incl. a better fan and a secondary watercooler) I think also the better airflow through the coolers make a difference. I noticed on my 335 as well that removing the fog lights and increasing the amount of air on the 2 coolers reduced the temps. At the moment I do not see any reason for a bigger oil cooler or an other radiator. |
05-13-2012, 11:26 AM | #20 |
Rep 812
Don't forget there are just far far fewer 1Ms than 135i / 335is....
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
05-13-2012, 01:31 PM | #21 |
Rep 212
Drives: VO
Technically the limp mode has technically been resolved on our N54T motors. It's die to the extra cooling, ECU re-mapping and more evenly distributed boost from the mapping.
