12-12-2014, 11:52 AM | #1 |
Rep 35
I need to go lower on my ST coils..Suggestions?
I recently installed some ST coils on my 135. The problem is that I have them adjusted all the way down on the rear and am still getting some wheel gap. On the front, I still have plenty of space to go down if I need to.
What are some springs I can find to go an additional inch or so lower? Is there any other alternative? I searched but couldn't find anything on the subject. Thanks for your help Here's a picture of how it currently sits. The rear is all the way down but the front is higher than I would like to compensate for the rear. |
12-12-2014, 11:57 AM | #2 |
Rep 169
If and when you take rear passengers, that gap will reduce significantly, so it's probably ideal how it is...
My ST's only have about 15mm left on the rear to go down, but i get alot of scraping even with 1 rear passenger, so for me i can't risk going any lower. |
12-12-2014, 12:00 PM | #3 | |
Rep 35
12-12-2014, 07:13 PM | #4 |
Rep 363
Man all these complaints about the ST couls not going low enough in the rear has got me scratching my head. Mine tucks if I drop it all the way in the rear. Had to raise it quite a bit when I first installed. Did you remove the cup the stock spring sat in when you installed the new adjuster?
12-13-2014, 06:56 AM | #5 |
Rep 35
I had a shop install them. I'll have to stick my head under and look. Man, if this ends up being the solution I'll give you ten thousand Internet high fives
12-13-2014, 09:32 AM | #6 | |
Rep 363
12-13-2014, 10:53 AM | #8 |
Rep 35
Yeah I just looked underneath. The perch that the stock spring fits in to was not removed. Looks like it was a shop error. Now I have to wait until monday to try and explain its his fault and get it in there in a timely fashion
12-13-2014, 12:28 PM | #9 |
Rep 4,531
12-13-2014, 10:56 PM | #10 | |
Rep 363
12-15-2014, 06:54 PM | #11 |
Rep 414
This is me with my kW v2 all the way down in the rear. From what I understand they're the same adjustability except for dampening. I never rub with 245 or 255.
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines.] |
12-16-2014, 04:15 AM | #12 |
Rep 614
Drives: BMW 120d e82 M Sportpaket
I can put 1 finger and a half with the minimal drop recommanded by KW/ST. I have to lower a bit now as it has settled.
I will post some pics later
M Sport package, Stage 1, CDV, BMC airfilter, VMR vb3, ST XTA, BMW Performance stuff, M3 arms, E93 M3 anti-roll bars F and R, ... French community of 1 and 2 Series: One-Two-Bimmers |
12-16-2014, 11:44 AM | #13 |
Rep 35
I took it back to the shop and he fixed it without issue in an hour and gave me another alignment for free as well as $100 off my next visit. I'm satisfied, and now my 135 looks like it should. I'll post pics soon
12-16-2014, 08:19 PM | #14 | |
Rep 363
12-17-2014, 04:45 AM | #15 |
Rep 614
Yep good to hear, can't wait for the pics Do you have the adjustement of the rear (mm on the perches) ?
12-17-2014, 10:15 AM | #16 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.22] |
Rare to find good customer service like this, stick with them going forward. Use that $100 credit for walnut blasting lol.
12-17-2014, 11:15 AM | #18 |
Rep 614
I think half way down is, rear, the perche at half distance of what KW/ST recommends.
In fact, it's my definition Then, front, will be the same ! Hope it helps you ! Another question c_ozanich: what's the distance between the middle of the centre caps and your fender ? Same question between tire and fender ? Thanks |
12-17-2014, 07:19 PM | #19 |
Rep 4,040
Drives: 130i coupé ;)
D2 coils go low... :/
Thats if you are okay with BC coilover clones
12-19-2014, 03:53 PM | #20 |
Rep 326
Drives: '11 MT E82
When you guys are talking about the piece that needs to get removed, you are talking about the black metal cup at the top, right? As opposed to the rubber piece that fits into the bottom of the spring?
2011 MT DSB 135i | MHD Tune | AA FMIC | ER CP | Wagner DP | Custom Mids & Axleback | KW V1s | VMR V701s | CDV & Clutch Spring Delete |
12-19-2014, 07:54 PM | #21 | |
Rep 363
12-20-2014, 04:37 PM | #22 |
Rep 326
Drives: '11 MT E82
Yea it's strange, I definitely removed that (with a hammer), but I still have about .5in wheel gap when all the way lowered on STs.
