07-02-2013, 08:15 AM | #1 |
Rep 154
Adaptive headlight warning - All works normal though
Hi all, i recently had moisture in my headlights do to me not putting the headlight cover on properly (it was dark in a parking lot so i couldnt see well). My headlight went out but my adaptive system still seemed to work. the headlight would zero when you turned it on and there was no errors. I just let the headlight dry out completly and replaced the ballast yesterday. When i pluged the headlights in this morning, both worked as they should however a couple min into running i got an adaptive headlight error, i turned the car off then tried it again, same error came up. My question is, do i need to have the headlight reprogramed for the new ballast? do they need to realign themselves or am i missing another step here?
07-08-2013, 03:09 PM | #2 |
Just one more taste...
566
Rep 2,011
I had an intermittent problem with an AHL CEL. I didn't have any moisture though. Dealership replaced the footwell modules, which didnt fix it. They replaced one of the motors that was shorting out occasionally and it's been fine since.
My Build Thread: Jet Black 6MT 128i with MSport
