      12-03-2018, 11:52 PM   #1
Cajun
Cajun
Drives: 2010 128i
Will 18x8.5et40 with 235/40/18 cause rubbing?
I'm looking into new wheels & tires for my 128i, but I'm not sure if 235/40/18 on 18x8.5et40 will fit. I saw a few people who ran 225, but I don't want any stretch.
I'm also looking at 18x8et42 with 225/40/18. Would that fit at all?
      12-04-2018, 07:17 AM   #2
crowtrobot
Drives: 2008 M3
I'm running 235's on 18x8.5 et45s, I needed a 5mm spacer up front to clear the struts, and have a 3mm spacer in the rear. 5mm in the back would rub under compression when the car was loaded with stuff. I also have ~ 2.0* of camber up front from the M3 control arms and Dinan camber plates, so keep that in mind as well.
My setup does not rub on the street or the track.
128i, fitment, tire, tires, wheel, wheels
