      12-31-2020, 04:43 PM   #1
Mike@N54Tuning.com
Joint Chiefs of Staff
Drives: 2007 335i, 2015 M3
N54/N55 BMW Transmission Cooler @ n54tuning.com
ORDER LINK
https://www.n54tuning.com/bms-e-chas...on-cooler.html
BMS E Chassis N54/N55 BMW Transmission Cooler
Everyone knows that heat is the enemy of your automatic transmission. And everyone knows that higher power levels generate more transmission fluid heat. Now you can extend the life of your automatic transmission by installing the new BMS High Capacity Trans Cooler kit. This unique plug and play kit replaces your factory coolant to trans fluid heat exchanger with a high capacity fender-mounted air to trans fluid radiator. Includes all mounting hardware, lines, and coolant caps required for installation. Installs inside the driver side fender providing ample airflow over the large cooling core via existing openings. The result is dramatically reduced transmission temperature and extended transmission life. This kit is strongly suggested for any BMW E chassis automatic running larger than factory turbos.
FEATURES AND BENEFITS
• Dissipates excess transmission fluid heat
• Reduces transmission fluid temperature
• Increases transmission life when racing
N54/N55 APPLICATIONS
BMW 1 Series
• 2008-2013 E81 E82 E87 Coupe and Hatchback 135i
• 2008-2013 E88 Convertible 135i
BMW 3 Series
• 2006-2011 E90 Sedan 335i/335ix
• 2006-2013 E90 E91 Sedan/Touring 335d
• 2006-2011 E91 Touring 335i/335ix
• 2011-2013 E92 Coupe 335is
• 2007-2013 E92 Coupe 335i/335ix
• 2006-2013 E93 Convertible 335i/335ix
Compatible with both RHD and LHD vehicles.
Not compatible with manual transmissions.
      01-06-2021, 01:52 PM   #2
Mike@N54Tuning.com
Bump for a Great Deal @ www.n54tuning.com
and as always the LOWEST price Guaranteed!!
Mike
      01-12-2021, 06:44 PM   #3
Mike@N54Tuning.com
Bump for a great deal @ www.n54tuning.com
Lowest Prices on the FORUMS!!
Mike
      01-19-2021, 07:09 PM   #4
Mike@N54Tuning.com
Mike
      01-26-2021, 02:59 PM   #5
Mike@N54Tuning.com
Mike
      01-28-2021, 08:15 AM   #6
Mike@N54Tuning.com
Mike
      01-31-2021, 10:49 AM   #7
Mike@N54Tuning.com
Mike
      02-02-2021, 05:15 PM   #8
Mike@N54Tuning.com
Mike
      02-06-2021, 05:03 PM   #9
Mike@N54Tuning.com
Mike
      02-12-2021, 07:02 PM   #10
Mike@N54Tuning.com
Mike
      02-18-2021, 06:10 PM   #11
Mike@N54Tuning.com
Mike
      02-22-2021, 09:03 AM   #12
Mike@N54Tuning.com
Mike
      03-05-2021, 04:41 PM   #13
Mike@N54Tuning.com
Mike
      03-11-2021, 04:01 PM   #14
Mike@N54Tuning.com
Mike
      03-14-2021, 06:54 PM   #15
Mike@N54Tuning.com
Mike
      03-21-2021, 06:33 PM   #16
Mike@N54Tuning.com
Mike
      03-23-2021, 06:14 PM   #17
Mike@N54Tuning.com
Bump for a great deal!!
ONLY @ www.n54tuning.com
Mike
      03-26-2021, 04:50 PM   #18
Mike@N54Tuning.com
Mike
      03-29-2021, 07:34 PM   #19
Mike@N54Tuning.com
Mike
      03-31-2021, 08:16 PM   #20
Mike@N54Tuning.com
Mike
      04-07-2021, 08:37 PM   #21
Mike@N54Tuning.com
Mike
      04-11-2021, 12:59 PM   #22
Mike@N54Tuning.com
Mike
