      07-03-2009, 09:31 AM   #1
BimmerLearner
My car is less than a week old and on its 3rd tank
BimmerLearner's Avatar
Drives: Tiag 135 Vert
About to install my berk exhaust
Any tips or tricks? im guessing the rear defusser needs to come off first.
      07-03-2009, 09:49 AM   #2
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
No, diffuser does not need to come off. It's really simple, but getting the hangers in and out is kind of a pain in the ass, but they're rubber so just push it real hard and it'll go eventually.
Use the zip ties they give you to tie up those flapper valve controller thing from the stock exhaust and leave it out of the way, then put the berk one on.
      07-03-2009, 11:54 AM   #3
BimmerLearner
man those holders suck, i got one off but in the end unbotled the mounts for other two... its ready to come off but how do i get that sensor off near the muffler?
      07-03-2009, 12:01 PM   #4
GtiGyver
GtiGyver's Avatar
Drives: 2009 Space Grey E90 328i MT
Quick question, since you probably still have your stock exhaust, could you take a picture of the inside of the central resonator?
Not the muffler but the mid-pipe resonator.
I just want to know if its a simple Y pipe glasspack or if it has baffles.
Thanks
      07-03-2009, 12:33 PM   #5
BimmerLearner
ill take a snap before i take it off the ramps...question, is it supposed to smoke that much? its really quite smokley when revving
      07-03-2009, 12:38 PM   #6
GtiGyver
GtiGyver's Avatar
yeah, thats normal. You're burning off some of the coating inside the exhaust. Can't really explain it, but its normal.
Give it one hour and it'll be gone, but it'll smell weird for a while longer.
      07-03-2009, 12:40 PM   #7
BimmerLearner
its a used exhaust so i thought it would be done... i hope i hooked it up correctly... where the two sections bolt i should feel a kind of gap right? feels like rubber seals between them.
      07-03-2009, 12:48 PM   #8
GtiGyver
GtiGyver's Avatar
There should be a gap, but they should not move. It should form an air-tight seal or you'll have an exhaust leak which sounds terrible. I don't think there is any rubber seal, at most maybe a steel ring but my understanding is the exhaust flange makes its own seal.
Smoke on a used exhaust? Did you spray anything inside the pipes? WD-40, release-all?
      07-03-2009, 01:55 PM   #9
BimmerLearner
Actually i think the smokings stopped; maybe it was just residue.
Interestingly its rattling, i have a vert and i can see where the exhaust rests on a cross bar... anyone have a solution for this? maybe a sticky rubber pad or something that wont melt.
Im not sure about the volume, wow its loud, little toooo loud inside the car with the roof down... might not stay on long.
      07-03-2009, 01:56 PM   #10
BimmerLearner
So maybe i dont have them flush together?
      07-03-2009, 02:00 PM   #11
scorcherjf
scorcherjf's Avatar
29
Drives: 2008 135i
2008 135i  [0.00]
Yea someone else put the exhaust on a vert and had trouble as well since the underneath has a different layout. They also said it was really loud... which surprised me since I actually think it's too quiet.
      07-03-2009, 02:02 PM   #12
BimmerLearner
scuffed the pipe getting it in there... but heres the flange and section after
      07-03-2009, 07:01 PM   #13
oneintheory
no longer a BMW owner
Drives: 2011 Ford Edge Sport
You have a PM about the part number.
      07-03-2009, 08:07 PM   #14
BimmerLearner
Thank you! id gone to advanced auto parts and just picked up a generic mount, seems to have done the trick. I took photos of the connection, i think i have a big old gap between the two parts, like the bolt hole slipped and is stopping the bolt tightening any further... back under the car in the morning again.
      07-03-2009, 11:24 PM   #15
carlosii
Puerto Rico
22
Drives: 2011 BMW 1M
The joint looks fine, you should not have any leak...
      07-04-2009, 12:58 AM   #16
bimmerboy
bimmerboy's Avatar
23
post some sound clips!
--2009 BSM 135i--
-Manual, Sport Package, BMW Assist
      07-04-2009, 07:12 AM   #17
BimmerLearner
yeah i went back under and tried to push a piece of card between the joints and it wouldnt go; guess its just an optical illusion... pity was hoping it would be the cause of the loudness. ill take some video on my iphone but the mic probably wont do it justice. atleast the rattle is fixed now.
      07-04-2009, 11:24 PM   #18
BimmerLearner
After running this for a day; I love the chatter, im guessing thats the waste gate, and the noise in ds under higher revs but its just too loud for me... going back to stock
