05-14-2015, 02:53 AM | #1 |
Rep 5
What's are the widest tires (front and back)that can fit on stock wheels?
Just got an 1M (been lusting after one since they first came out) and I am looking to upgrade the tires (OE spec PS2) to something wider and grippier.
What's are the widest tires (front and back) that can fit on stock wheels without rubbing? Any input would be greatly appreciated. Thanks! |
05-14-2015, 06:12 AM | #2 |
Homyseed
69
Rep 261
You could go for Michelin PSS wich is the usual upgrade, grips and last longer.
I'm now on Advan AD08-R in 255 and 275 on stock rims, goes pretty well except the rubbing on full lock turning left. Watch out, AD08R is a WIDE tire, meaning the 245 is already like the PSS 255...
NOW: '11 BMW 1M AW "Nabila"
PREVIOUS: '09 BMW 335i DKG (DCT) "never too big" BEFORE:'09 BMW 135i F1 Sauber Edition 120/135 Team Homyseed |
05-14-2015, 09:35 AM | #3 |
Rep 2,898
Lots of threads on this. Easily found if you search.
Here's one: http://www.1addicts.com/forums/showt...t=widest+tires Neil |
05-14-2015, 10:03 PM | #4 |
Rep 2,819
Drives: e82 1M, f87 M2cs
I just saw that the new Bridgestone RE-71R (treadwear 200, yeah right, for autocross) is available in 255/35/19 and 275/35/19. That may just be my tire for next year. I have the updated front fender liners, so hoping they will not rub.
I will return and report . . . in a year! |
05-16-2015, 05:46 AM | #5 | |
Rep 562
Drives: 2011 1M VO
05-16-2015, 12:51 PM | #7 |
Supreme Allied Commander
3816
Rep 54,319
Drives: F80 M3
255 front and 275 rear are good upgrades over stock. You can't go wrong on the street with PSS tires.
05-17-2015, 11:34 PM | #8 |
Rep 2,819
That is too bad, planning to do a little of each. I'm currently on RE11's which handled the track pretty well, grip was consistent through the sessions. They don't really come up to temp at autocross, and their tread wear rating makes them a "race" tire with this years rules.
05-24-2015, 04:21 PM | #9 | |
Rep 630
And don't wait a year to report. You should notice the minute you make a tight turn.
Matt Murray
I am perfectly capable of learning from my mistakes. I will surely learn a great deal today. |
05-24-2015, 10:37 PM | #10 |
Rep 2,819
My RE-11's are probably going to last me this whole summer, thus the year.
05-25-2015, 09:16 AM | #11 | |
1mGator
144
Rep 567
05-25-2015, 12:14 PM | #12 |
Rep 170
I have the same set up, and agree
2011 1M, Valencia Orange
2002 IT2 Nissan Sentra, Racecar Green Board Member, Western Canada Motorsport Association http://www.wcma.ca/new/ |
05-26-2015, 01:05 PM | #13 |
Rep 294
Hi. If you want to go wider on stock wheels and have no rubbing issue, you have to change your front fender liners, then 255 front - 275 rear will fit easily.
I have Michelin Cup 2 255-275.
Spa-Francorchamps : The Beauty
Nürburgring Nordschleife : The Myth |
06-12-2015, 03:20 AM | #14 | |
Rep 585
Which ones do you recommend? Do e92 m3 fit? I thought they were the same as oem 1M ones? |
06-14-2015, 11:06 AM | #15 |
Rep 294
Here it is :
http://www.realoem.com/bmw/enUS/show...diagId=51_6961 You have to ask for : front left = part# 51 71 8 051 591 front right = part# 51 71 8 051 592 Please ask for the MODIFIED fender liners because this number is the same compared to the original ones !! PUMA BMW code : 49636119-01 Here's the difference between the normal liner and the modified one : There's a sticky about it ==> http://www.1addicts.com/forums/showthread.php?t=682196
03-18-2016, 10:08 PM | #16 |
Rep 2,819
I am now using the RE71r's 255/35 front and 275/35 rear. I had two long 30+ minute track sessions last Sunday (temps were 50-55 degrees in the afternoon) with no overheating issues. We'll see how they hold up as we get into summer.
03-21-2016, 08:45 AM | #17 | |
Rep 220
They are easily the stickiest 200tw tire I have used but I have gotten 2x as many days out of the other usual suspects in 200tw rating (RS3, Direzza Z2). RE-71 is as sticky as an R comp and wears like one too, in my experience at least. |
03-21-2016, 04:15 PM | #18 |
Rep 2,819
Hard to tell from 1 track day. I don't have a tread depth guage. I do 3-4 track days and 3-4 autocrosses per season, plus about 8000 miles. I will be happy if they last 1 season.
03-23-2016, 04:44 PM | #19 | |
Rep 1,479
Drives: 2017 F80 M3
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
03-23-2016, 05:30 PM | #21 |
Rep 1,479
Drives: 2017 F80 M3
why would that matter? if anything a lowered car should have less outer edge tire wear due to the lower center of gravity.
Tags |
fitment, tire, wheel |
