      11-03-2013, 01:24 PM   #1
mechavore884
mechavore884's Avatar
Drives: the fat mobile
CEL & error p0440
Hey guys,
strangely enough my check engine light came on (about an hour ago). I pulled into advance auto to scan the codes and it seems it spit back 3 errors all of which "P0440 Evaporative emission system." From the little bit of research that I did some say that its the gas cap "which I have removed and reseated and not luck whatsoever". Has anyone seen this error AND FIXED IT?...also is it something I can drive on? plz let me know and since Im a noobinite keep the flaming to a minimum?!?!??!?
      11-04-2013, 05:17 AM   #2
mechavore884
lol anyone?
      11-04-2013, 06:36 AM   #3
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
You need to clear the code to check if your gas cap technique worked.
You are on the right path though.
      11-04-2013, 09:07 AM   #4
mechavore884
gotchya, just cleared the code an no luck....should i try purchasing a new gas cap? (granted the car only has 55k on it) but I have read in some cases its the vapor sensor?
      11-04-2013, 09:10 AM   #5
TheSt|G
TheSt|G's Avatar
Or the lines and such. I doubt your gas cap went bad.
      11-04-2013, 09:43 AM   #6
mechavore884
I was thinking soo too, since im still new to this motor where are the lines located? I may try to run a leak test this afternoon (also if you have pics that would be AWWWEESSOOOMME)
