      11-27-2011, 05:31 PM   #1
07'335iAlpine
Drives: '10 135i M-Sport
Procede help.....
Hello,
I installed my procede about 2 weeks ago and i got to say i love it. I recently just downloaded the beta aggressive maps. before when i used to hit the cruise control stock with the gauges showing the auto tuned boost level it would say 13.5 in map 1 and 14.5 in map 2. Now after installing the new aggressive beta maps i am checking the auto tuned boosts levels for each map and it show slightly over 10 for both maps no change between both of them as it did before at 13.5 and 14.5psi. Is there a way to reset the procede to back to the way it was originally and then just redownload the maps to see if the boost values change between map 1 and 2. Thanks in advance for any help.......please chime in soon this is really worrying me. Oh yea and after the beta maps have been put in I'm throwing a SES light.
Thanks,
Jacob
      11-27-2011, 05:35 PM   #2
sear
Drives: 2007 335xi
Originally Posted by 07'335iAlpine View Post
Hello,
Thanks,
Jacob
Can you post a screen shot of your user settings? What stage maps did you load and what other mods do you have?
      11-27-2011, 05:39 PM   #3
07'335iAlpine
I uploaded the stage 1 aggressive. it had the option for stage 2 and stage 3. but I'm stock other than the tune. i uploaded the maps at a friends house with his laptop so i can't get a screen shot but my laptop which was getting fixed is on its way to me within the hour so i should be able to do so then. as well and hook up the procede and read the SES light its throwing. Thanks.
      11-27-2011, 06:19 PM   #4
RaihaX
RaihaX's Avatar
Drives: 08' 135i
autotune is disabled for the aggresive maps.
      11-27-2011, 06:53 PM   #5
sear
Drives: 2007 335xi
sounds good,post codes and screen shot if your still having trouble after you get the laptop. The most common way for this to happen is to not follow the firmware/map loading instructions to the letter in the readme.txt file (reset of adaptions, etc) Just redo the firmware/map load again following the readme.txt file... good luck
      11-28-2011, 11:19 AM   #6
bryce
Drives: zhp 3-pedal
the new aggressive maps don't show the accurate boost and ignition correction values when you "hijack" the gauges. stage 3 aggressive maps show about the same thing (10-11 psi). if you monitor boost on the fuel gauge, you'll see that it's running higher
      11-28-2011, 06:51 PM   #7
07'335iAlpine
Thanx guys
Appreciate the help bryce is right I'm seeing 15 psi consistently. thanks for the help. However we had a really cold morning 35 degrees and a triangle with what looked like a snow flake popped on when i started the car. and it was running like shit, i stayed out of boost cause if i gave it too much gas the whole car would shake felt really ugly.......hope i didn't screw anything up.
      11-28-2011, 06:56 PM   #8
RaihaX
RaihaX's Avatar
Drives: 08' 135i
Mine also get a frost warning when it gets too cold - but car usually runs fine? sorry not much help
      11-28-2011, 07:27 PM   #9
07'335iAlpine
you didn't feel no shaking after you got the frost warning or did you let it idle for awhile before taking off. Mine felt like engine was going to shake apart.
      11-28-2011, 07:39 PM   #10
RaihaX
RaihaX's Avatar
Drives: 08' 135i
The couple of times I got the frost warning is when I am already on the freeway so is a little bit different to you. My car is already running for about 5 minute by then but it only stays on for like 5-10 second before it goes off again.
      11-28-2011, 11:28 PM   #11
sear
Drives: 2007 335xi
Its not very likely that the frost warning has anything to do with the shaking. Are you able to read codes yet? You could be misfiring. How old are your plugs? Many threads on this topic, but plugs don't hold up as long while running a tune as they do stock on this platform. When they are starting to go, cold start can be one of the times where they show their age first.
