      04-05-2015, 07:29 PM   #1
Boosted_N54
Boosted_N54's Avatar
180
Drives: 135i N54
pictures of piston wear and spark plugs
pulled out my spark plugs today to check them out and i put a snake camera were the spark plug goes in to check out my pistons. Cyl.1 and Cyl.5
are these normal wear ?
64,000 miles
last time i changed my plugs was at 53,000 miles
FBO cobb stg2+ 93oct
i just had my oil sample results from Blackstone Labs because i thought i might of had injector fuel leak and the result came out very good . they didn't find anything.
RESULTS> http://www.1addicts.com/forums/showthread.php?t=1110689
when i took the sample the oil did smell like fuel though.but as they said they didnt find any of that
what do you guys think?
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
      04-05-2015, 07:58 PM   #2
e36addict
Drives: 2013 X1 35iX
Sure you don't have an injector leaking? That piston top looks awfully wet. Run rough on cold starts?
      04-05-2015, 08:01 PM   #3
Freon
Drives: 2009 135i
Those plugs look fine. Definitely not very worn, which makes sense with ~10k on them. I changed a set at about the same interval for curiosity and they looked similar. My first set changed at 30k were severely worn!
      04-05-2015, 09:36 PM   #4
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
FWIW, I would say if they didn't find any fuel in your oil, then you don't have to worry about having any fuel in your oil.
Combustion chambers take on all kinds of smells, don't let a plug be your guide (as far as your nose is concerned) about how things are going.
      04-06-2015, 09:53 AM   #5
135Pats
135Pats's Avatar
Drives: A few BMWs
When did you pull the plugs - right after driving? Right after a cold start? After sitting overnight?
The plugs look OK relatively speaking but are wet/fouled with something. Looks more like fuel than oil.
F30 N55 XDrive EBII
      04-06-2015, 09:55 AM   #6
MightyMouseTech
MightyMouseTech's Avatar
4338
Just looks like the engine was started cold, and was not fully warmed up before pulling the plugs.
      04-06-2015, 01:17 PM   #7
Boosted_N54
180
Drives: 135i N54
this is correct. the car was parked right out side my house and I started it up to pull it in the driveway. so I can pull out the plugs
      04-06-2015, 01:38 PM   #8
MightyMouseTech
4338
Bingo.
      04-06-2015, 04:18 PM   #9
Boosted_N54
180
Drives: 135i N54
so I'm guessing the pistons look normal?
      04-14-2015, 09:39 PM   #10
dojk
Drives: E82 135i
Isn't that considered heavy carbon buildup?
      06-01-2015, 12:31 AM   #11
Boosted_N54
180
Drives: 135i N54
is this how piston should look? 65,000 miles ?
      06-01-2015, 10:32 AM   #12
135Pats
135Pats's Avatar
Drives: A few BMWs
That's a fairly loaded question. We're not going to be able to answer that with just a boroscope picture of a wet piston crown. It's seen 65K miles so it's not going to be some shiny beautiful piece of metal.
Is there an issue you are trying to track down? Is compression dropping across a cylinder or bank?
Pistons do seem to be the relative weak spot of the bottom end but unless you are running a very aggressive tune or are dealing with a huge amount of pressure/heat in-cylinder, there shouldn't be an issue south of 700WHP or so.
F30 N55 XDrive EBII
      06-01-2015, 09:49 PM   #13
Boosted_N54
180
Drives: 135i N54
no not really . i was just bored one day and wanted to see how the piston look like. thats all and once i saw the picture i was like. HMMMMMM
