12-17-2010, 09:16 AM | #1 |
Rep 134
will rim style 137 fit my 135?
im looking to buy a set of winter tires. Just wondering if they style 137 off an 05 330xi will fit my 135i? ik the bolt pattern is correct and everything but i am weary of the brake clearance. Im a noob when it comes to this stuff so accurate advice would be much appreciated.
2009 135i coupe | 6MT | Montego | M sport | Nav| Split Second Turbo Tuner
2014 335i | 6MT | M Sport | M sport brakes | Nav | Harmon Kardon | 19in factory performance rims | JB4 | K40 radar detector and laser jammer |
12-24-2010, 12:45 PM | #2 |
Rep 240
Fit
the style 137 has the same specs of the rims I just put on--17x8 with an ET47 offset. Mine are another style but don't see why yours would not work ok also. I mounted 225x45x17 Michelin winters on them. Of course the best answer is to be able to physically try them.. The rears I am confident will be ok. The fronts are usually the question because of the large caliper and the strut. Bolt pattern is 5x120 on our 135i. You would want to make sure the centering hole is the same deminsion but I believe all of the later rims are ok--dealer can tell you. Hope that helps----you should be good.
