      09-03-2012, 09:33 AM   #1
.b0link
Drives: 2012 LMB 135i
Dumb question/first turbo car
Ok, hate to ask what seems like could be such a dumb question, but this is the first turbo car I have owned so my experience is limited.
Installed a JB4, and Axle back Berk Sport. Everything else is stock. Just rolled over the 1200 mile break in.
As the weather gets nicer I have been rolling with my windows down. When on the highway next to a jersey wall I can hear a lot more of the exhaust and sounds the car is making.
When under full power/load, there is a noise that I am not used to hearing. Its not a turbo spool noise but a very raspy almost rattle like sound with the exhaust. It doesn't necessarily sound bad, but ive never had a car that makes this distinct noise before. It almost sounds like some of the heavily tuned cars with massive down pipes kind of noise that I have seen in youtube videos on here. Is this a normal sound for a N55 running stock DP?
Like I said, this feels like a dumb question but, I was thinking that this car when stock wouldnt make that kind of racket. Go easy on me lol. My mechanical/automotive knowledge extends almost exclusively to motorcycles. Im hoping that this is just the normal sound cause it is pretty nasty
      09-03-2012, 09:40 AM   #2
Zombie1
Drives: BMW 135i 2010
Hmmm
You sure you have your exhaust bolted On straight with a good gasket? Maybe it's a slights ratted on the seem where you bolted on your axle back under full throttle maybe post a video?
      09-03-2012, 09:46 AM   #3
.b0link
Gasket is reused from stock exhaust...looked like a teflon weave kind of deal that was attached onto the end of the midpipes. Instructions said that it is re-usable and to re-use it. I will get it underneath sometime this week and check the bolts. Don't see how they could come out with the springs loading them though.
      09-03-2012, 10:18 AM   #4
stevenc
Coming Soon
Drives: 2015 BMW M4 Alphine White MT
may have a slight exhaust gas leak. I had a leak when I first installed my midpipes and I went back under, gave the bolts an extra turn and that did the trick.
      09-03-2012, 10:48 AM   #5
Zombie1
Keep us posted
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
