07-06-2014, 06:51 PM | #1 |
Rep 202
Misfire cylinder 2 any input?
So today I got a misfire in cylinder 2 at WOT. Spark plugs were changed less than 10k miles ago. Car is approaching 63k miles and is fbo any ideas? I'm thinking coil pack
*UPDATE* I swapped the coil and the misfire followed. Replaced the coil and shes running like new
[B][COLOR="Red"]Vrsf 3'' Dps~Vrsf 7'' FMIC~AA Gen 2 Exhaust ~BMS DCI
~VRSF CP with Tial BOV~Cobb V3 With Custom PTF E40 stg2+ Tune Last edited by Kosta135i; 07-11-2014 at 02:59 PM.. |
07-06-2014, 06:59 PM | #2 |
Rep 1,335
usually it's your coils. i had a misfire in cyl #4 and #5 so i changed the plugs. same misfire happened at WOT. changed out #4 and #5 coils and she's running new again.
6MT/ Sport Package/ N54/ Asa wheels/ Eibach pro kit springs/ Active autowerke Exhaust/ 35% tint
07-06-2014, 07:19 PM | #3 | |
Rep 202
~VRSF CP with Tial BOV~Cobb V3 With Custom PTF E40 stg2+ Tune |
07-08-2014, 07:58 AM | #4 |
Rep 146
If it's the injectors and you can be without the car for a couple of days Marrion Injectors can clean / blueprint them pretty inexpensively. I'm having mine done (different car) and the cost for four is right around $100 total. Injector.com
And they're located in CT. I dropped mine off to their ship; they only charge/ $10 for next day delivery in CT. But sounds like what I'm experiencing; a bad coil. ~ $50
Dave Gran
Free Guide to Motorsports AND Car Reviews from an Enthusiast's Perspective GoAheadTakeTheWheel.com |
07-08-2014, 08:02 AM | #5 |
Rep 22,992
Usually in this order... spark plug/coil pack/injector/carbon buildup.
Easiest thing is to move that cylinder spark plug to another spot, and see if the misfire code moves. Then you will know what you next step should be.
07-08-2014, 09:10 PM | #6 |
Rep 51
hook up pressure gauge, activate injectors VIA diag scan tool, watch pressure on each individual injector activation. This will determine if injector is the issue. Misfire can also be caused by faulty vanos solenoids. My cylinder 3 misfire was due to faulty intake vanos solenoid.
07-09-2014, 11:42 AM | #7 |
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
Had the same issue but on C1, do the swap to diagnose if it is just the coil.
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
07-10-2014, 08:23 AM | #8 |
Rep 6
Seems to be a fairly common problem with the 1? I was looking through other threads a few months ago for the same problem and the bimmerfest forums had a lot of similar issues. Ultimately it was a coil, but the problem has since returned and I need to replace another. Thinking of just upgrading to the high perf ones anyway...
07-10-2014, 09:46 AM | #9 |
Rep 146
What are the high performance ones that you're considering?
This seems to be a pretty common issue. My car is also mis-firing and already changed plugs. Are these an item that all should be replaced at a specific mileage like plugs?
Dave Gran
07-10-2014, 10:12 AM | #10 |
Rep 2,224
I've never heard of high performance coils. Anyone have info/link?
Mine is fine but I like to do preventative maintenance. Its my daily driver and I depend on it for work all year, so I want to keep it running at top shape. |
07-10-2014, 10:25 AM | #11 |
Rep 6
I'm fairly certain bav auto had... I looked into it when I first had this issue. Money has prevented me from pursuing it though. Looking at site now, I don't see, but I know I tore out the page from the catalog. As soon as I find them online I'll post the link. I was interested in the extra hp. The car is my daily, but I beat the crap out of it at Autox every weekend.
07-10-2014, 08:28 PM | #12 |
Rep 146
Ah, okay. My guess is marketing got that.
Dave Gran
07-11-2014, 06:13 PM | #13 | |
Joint Chiefs of Staff
24190
Rep 190,802
