      04-19-2016, 05:55 PM   #1
Bigtimers227
Drives: Modded 135i
N55 NEED HELP TURBO/pan LEAKING
2011 n55 e82 135i so just got back from the shop where they told me I need to now replace the oil pan gasket and turbo lines/seals...
My question is this:
They told me 790$ ☹️ for oil pan gasket to be replaced and then they said That the previous owner must have had an upgraded turbo on it and reused the crush washers and seals that go on the oil lines from the turbo to motor or pan when he switched back to stock to sell it. (Don't remember word for word). I'm super pissed. Because that is another 1700$ to fix.
I don't know if I'm being had or not. This place specializes in bmw I don't want to reveal names cause a lot of you will prolly know the shop or the owner could be.a member to the forum
Is 790$ for oil pan gasket to be replaced to much? Or is that cheap. And is 1700$ for all new turbo seals and lines too much? that's with the 10hr labor discount... It was 2400$ instead of 1700$<--- THOSE ARE THE QUESTIONS
I've done all my own work for years from pulling motors on toyotas to replaceing gears in trans. I'm currently a painter. Just don't have my own lift and car is super duper low low style. and I paid way to much to turn wrenches and fuck it up further for myself cause I've done a lot of that aswell hahahahahah any insight much apriciated.
      04-19-2016, 06:01 PM   #2
Bigtimers227
Drives: Modded 135i
Car is FBO
      04-19-2016, 06:02 PM   #3
Bigtimers227
Drives: Modded 135i
Cobb ots map for now detuned with stock turbo
      04-20-2016, 02:05 PM   #4
NickDHdfc
Drives: 2011 135i
Your best bet is to call around to local indy shops and see what their pricing is. I wouldn't settle for one shops price. Call shops for other states too. There's a lot here in eastern PA. Get some knowledge from them and report back.
-Nick
2011 135i M Sport 6MT
Berks Race Exhaust|PLM Catless DP|ETS CP|BMS Intake|JB4 ISO|Flex Fuel|BMW LCI Blackline Taillights|Rieger 1m bumper|Rieger Diffuser|Apex ARC-8
      04-21-2016, 03:43 PM   #5
loesch
loesch's Avatar
Drives: 2011 BMW 135i M Sport
You know I bet the oil pan gasket is fine. The first time I changed my turbo I re-used the oil line o-rings. Well, one got pinched on the way in and it was leaking a little. The oil is so thin that it followed the oil pan gasket all the way from the trans to the front of the engine. It really looked like the oil was coming out of the pan. I fixed it in 30 minutes by installing new o-rings. The bottom oil line was the one that was leaking so I could remove it without even taking apart the thermostat or water pump.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
