      01-25-2011, 11:53 AM   #1
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
225/255 Setup, Any Downside
I see a lot of talk in this forum about running 225/255 tires instead of the stock 215/245 setup.
Are there any downsides to going up a size on a 135i? This would be on an otherwise completely stock car that is not driven on the track ever.
      01-25-2011, 01:38 PM   #2
Gary@TireRack
Moderator
Gary@TireRack's Avatar
Drives: Formerly 1995 M3
No downside at all. IMO, these should have been the OE sizes.
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      01-25-2011, 02:47 PM   #3
My135
Drives:
How about front 235/40 rear 255/35 combo? Is 235/40 too wide on front? Thanks.
      01-25-2011, 02:55 PM   #4
Diver
Diver's Avatar
That is a pretty strong recommendation coming from a tire guy.
      01-25-2011, 04:10 PM   #5
My135
Drives:
The tires were mounted on Breyton GTS-R wheels. The sellers said they won't rub; but I saw most people installed only 225/40 instead of 235/40 on front; kind of wondering.
      01-26-2011, 10:59 PM   #6
new2the3
new2the3's Avatar
Drives: 2020 X3M Competition
235/40 is a taller tire then 225/40, I wouldn't do it.
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB
      01-27-2011, 08:01 PM   #7
cpt97m3
AutoXer
34
Drives: 2009 135i
+1. It's a 1/2 inch taller diameter, and a little wide for a 7.5" wheel.
      02-08-2011, 11:07 AM   #8
Diver
Diver's Avatar
I kind of feel the original point never got discussed fully here as the thread got hijacked by a question about a different tire size. To repeat, the car will have stock wheels & suspension.
      02-08-2011, 11:18 AM   #9
new2the3
new2the3's Avatar
The first reply fully answered your question. There is no downside, absolutely nothing you would notice. The majority of the members who keep stock rims use a 225/255 setup.
2020 X3MC
      02-08-2011, 12:58 PM   #10
Cisitalia
No fast lane bandits allowed
Cisitalia's Avatar
Drives: 2009 135i TiAg 6mt M-Sport
No real down size other than the stock 7.5" and 8.5" rims are not ideal widths for the 225/255 tires but work fine with no problems. Wheels widths of 8" and 9" are better suited for 225/255 tires but not absolutely necessary.
I put Conti DWS 225/40-18 and 255/35-18 on my stock 261M wheels and they work just fine for my "winter setup". When I got my CS7 wheels which are 8" and 9" widths, I put Goodyear F1 Asymmetrics (225/40-18 and 255/35-18) on and they fit great. Now I think that is the perfect wheel/tire size that should have been standard on the 135i.
      02-08-2011, 03:25 PM   #11
Frack
Euro Member
Drives: SGM e46 M
got it, love it... although... I'm planning on running 17's this season with 265R
SGM e46 M
      02-08-2011, 08:46 PM   #12
IDBMW
IDBMW's Avatar
Drives: 2019 X3 M40i
I have that set up. I bought the tires and wheels from Tire Rack. The car rides and handles much better than the stock the wheels/tires. No regrets. And I have the stock suspension.
2019 X3 M40i - Black Sapphire Metallic - Mocha Lather - 21" 718M wheels - Every option except Sun Shade
      02-08-2011, 09:30 PM   #13
1013mm
aka 1013MM
1013mm's Avatar
Hong Kong
1253
Drives: pokingly flush
2009 135i  [8.26]
no down side they will fit.
      02-23-2011, 02:55 PM   #14
DarkstarZero
DarkstarZero's Avatar
Drives: Daytona 95 M3, X7 M50, e92 M3,
I'd worry about rubbing on full lock - this happened to me on my late C32. You don't notice until you take the wheels off and look under the arch. Also, remember that when you change your tire height your speedometer will be off so it's not like there's no down sides. A recalibration will run you $100 usually.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center!
Enter Referral ID: 420186
      02-28-2011, 10:23 PM   #15
MrBimmer
Rated M
MrBimmer's Avatar
Drives: 1M
the speedo is already off by 3 mph in my car on stock everything. will going from 245-255 in the rear make it worse? or is it more specific like 255-35 vs 255-40
      03-17-2011, 09:48 PM   #16
Delta Goose
Drives: '09 AW 135i
Why does your site tell me that the 255 Hankook V12's may require fender modification?
      03-17-2011, 10:20 PM   #17
Yogijet
British Virgin Islands
14
Drives: 2009 BMW 135i, Jet Black
Haven't suffered any on the stock suspension running these on Michie PS2s with stock wheels. I'm very happy. Big test is whether they will fit under the BMW PS which is on its way but I think they should fit there as well.
BMW Performance Exhaust, Michelin Pilot Supersports F-225/40, R-255/35, BMW Performance Suspension, BMW Performance black kidneys, Quaife LSD, M3 rear sub-f bushings, M3 front control arm, rear guide rod and rear upper link kits, BMW Performance cross-drilled/slotted rotors, AFE Cold Air Intake.
      03-17-2011, 10:25 PM   #18
Yogijet
14
I agree with that, and when I feel ready to cough up the dough for the Yoko Advan RZs, I think I'll go with the 8" and 9" widths.
      03-18-2011, 10:24 AM   #19
ptack
ptack's Avatar
2008 135i  [6.50]
Hankooks are pretty square shouldered. I run 255s on Forgestar F14s and one of the 255s rubbed a bit until I had the fender slightly rolled. Can't say for sure about how they work on OEMs.
      03-18-2011, 10:50 AM   #20
Delta Goose
Drives: '09 AW 135i
I'm going to be putting them on VMR V701's, you think they will be fine?
      03-18-2011, 07:03 PM   #21
With the 225/255 setup wouldn't you have more sidewall flex over a RSC (run flat tire - in the 215/245 size)? This is my main concern. I really do not want to loose ANY steering response with my 135i.
The 225/255 setup seems very temping though.
Also... my local tire dealer here in Germany looked up in a book the max size tires you can mount on wheel widths and size. For the OE 18' M-wheels (7.5" & 8.5"s ) he told me that 225's and 245's are the biggest tire I could safely put on the wheel. That is also what TUV says too. But... I do not have to worry about TUV since I have US tags thru the Army.
Comments?
Dackel
      03-18-2011, 07:30 PM   #22
VMRWheels
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
With a 8.5 +45's coming in and 9.5 +50's available, 225/255 at stock height would be perfectly fine.
-Charles@VMRWheels
