12-10-2010, 04:44 AM | #1 |
Rep 9,134
1er M /// Twin Scroll or Twin Turbo?
12-10-2010, 04:57 AM | #2 |
Rep 9,134
A few months ago, Scott26 wrote:
...I am going to give you a clue.... The 1M powertrain is a Hybrid. And when I mean Hybrid do not think of the current meaning of "Hybrid" - ie Alternative power , Electricity etc.... and use the original meaning of hybrid. " When Two seperate entities become one". |
12-10-2010, 05:14 AM | #4 |
Rep 2,340
Drives: 650GC/E93M3/Lexus LS600HL
Twin Scroll + Twin Turbo!!!!!
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT 2011 F10 550i M Sport - Retired |
12-10-2010, 05:19 AM | #5 |
Rep 1,898
it the BMW press release it is written that it has two small turbos. But I am confused about the text as well. Technically, 2 twinscrol turbos are not possible with a 6 cylinder engine.
12-10-2010, 05:46 AM | #7 |
Rep 1,898
12-10-2010, 05:59 AM | #8 |
Rep 9,134
Your saying a single turbo cannot be mounted on a n54?
I know what they said. But I also know twin~power is the new term for the twin scroll turbo on the 2011 and newer x35i models. |
12-10-2010, 06:22 AM | #9 |
Rep 4,848
1M engine specs = z4 3.5is specs. Improvement in acceleration for both was also 0.4 from 0-100 compare to the x35i counter part. Apart from the extra cooling (just referring the engine), I couldn't see any improvements over the z4 is, just looking at its specs. The difference is the 0.4s improvement for the z4 was achieved using a DCT, while both the 135i, 1M both uses a manual transmission.
It doesn't answer the poser question, but on the surface, it seems that both engines are the same - ie twin turbo, but the results are somewhat different?
Macan Turbo - White 1///M - Valencia Orange |
12-10-2010, 06:56 AM | #11 |
Rep 4,190
12-10-2010, 07:42 AM | #12 | |
Moderator / European Editor
1552
Rep 6,754
Best regards, south
12-10-2010, 08:17 AM | #13 |
Rep 1,898
what I was referring to is putting 2 twin scroll turbos on a N54 (or any 6 cylinder engine).
12-10-2010, 09:42 AM | #15 | |
Rep 2,898
However, I don't believe that this is the case since the hp/torque figures that have now been published are identical to the Z4 sDrive35is. Based on this, I suspect that the hardware and software are the same. I would, of course, be delighted if I were wrong! Neil |
