04-18-2012, 07:00 AM | #1 |
Rep 758
Brakes - How low can you go?
The front brakes have taken an age to wear down from my original post on this. Right now I have 1900km left. Is that too low and should I place an emergency call to bmwroxm5 to get them done ASAP?
Thanks Byron |
04-18-2012, 07:06 AM | #2 | |
Rep 22,992
The search function is your friend...
Quote: Originally Posted by Xyloft So the brake counters in the dash are actual wear sensors and not just mileage counters? when I checked my counters at 52,000 it said 16,000 more for the fronts and 20,000 more miles for the rears. Quote:
http://www.1addicts.com/forums/showt...ad+wear&page=2 |
04-18-2012, 07:13 AM | #3 |
Rep 758
Sorry I missed that thread in my search.
What I find confusing is that the service guy told me I had 1mm left on the front disks ~7000kms ago at which time the brakes said they had 4000km or so left and I keep wondering if they are below spec now. I understand the sensor is in the pad and not the disk so the disk could be low with some pad remaining. Mind you the brakes still work! Byron |
04-18-2012, 07:26 AM | #4 | |
Rep 22,992
It is a safe bet that your car now need front pads (and probably brake rotors) and one pad sensor. Normally the rear pads wear(out) at just about same time as the fronts. For the rears I think you can get by with just pads and one pad sensor. Dackel |
04-18-2012, 05:03 PM | #7 |
Rep 3,070
Drives: A boring one...
I did 90,000 kms on my front pads... Approx 20,000 more than when the car said they needed replacing.
04-18-2012, 07:43 PM | #8 | |
Rep 552
04-19-2012, 12:08 AM | #9 |
Rep 3,070
Yeah I didn't see the need, plus I just never got around to organising it. If it aint broke...
04-19-2012, 12:45 AM | #10 |
Rep 839
When my brake warning light went red because the sensor had been eaten up. I looked at them and they had a ton of meat left. I drove it another 7000km (including a track day) and when I replaced them they still had 3-4mm on them left.
the indicator is just an indicator
'09 BMW 135i, Lemans Blue
'97 Nissan Skyline R33 Series II GTR V-Spec |
04-19-2012, 02:38 AM | #11 |
Rep 3,070
The indicator is really the 'time to give money to BMW ' indicator
04-19-2012, 05:35 AM | #13 |
Rep 4,995
04-21-2012, 02:11 AM | #14 |
Rep 741
Drives: E87 130i
I ignore it. I had a sensor go when I was at ~50% pads. I only learnt this after fitting a front BBK to replace it.(cheaper than parts through local BMW stealership)
