      10-29-2015, 11:47 AM   #1
Fast.asleep
Drives: 2009 128i
Replace cup holder trim
When I bought the car the trim that the passenger cup holder fits into was broken. The piece is cheap enough but do I have to remove the entire console to replace?
This is the piece I'm talking about
      11-04-2015, 11:55 AM   #2
Fast.asleep
Drives: 2009 128i
Just in case anyone else is researching this:
The trim piece is held on by 2 screws that you can only access from underneath the console. I'm sure complete removal isn't nessicary but there is no easy way to do this.
      10-04-2021, 04:14 PM   #3
PleaseFix
PleaseFix's Avatar
Drives: 128i 2012 MT M-Sport Pkg
2012 BMW 128i  [0.00]
I have the same issue with mine! So does the entire console need to be removed? I wonder if you can access it by removing the shifter.
      10-13-2021, 11:10 AM   #4
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
Yeah the whole center console trim needs to be removed to access the screws from the underside. There's a DIY to install the cupholder around here that will guide you through it, not tooooo hard, but is a bit of a pain. Curious how is it actually broken? One of the ears you think that hold it in place are broken or something? Or just the door is loose or what?
