      01-18-2019, 08:10 AM   #1
Blu3RSX
Industrial Designer
Blu3RSX's Avatar
Drives: 2013 135i. It's blu3 ^_^
Relocated the water pump? Anyone? Bueller?
Okay, so, I'm sure most of you are all pretty familiar with the infamous electric-driven water pump.
Personally, I think it's a great idea that this component is NOT mechanically driven because it does eliminate itself from the equation of parasitic horsepower loss.
However, I think the engineers missed the ball with its location.
My question is this: has anyone here relocated their water pump to a place in the engine compartment where it was easier to get to?
For example, I rarely, if ever, use my windshield washer because I'm a big fan of Rain-X and just clean my windshield at the gas station during fill-ups. In this case, I would just put the water pump / thermostat in that location where it would also probably help to dissipate heat since it's not right near the engine.
Just curious what the forum might think about this and any pros / cons about this modification.
Cowl Delete
Injen Intake
BMS Stage 1
BMS Pedal Tuner
ARM 5" Intercooler
      01-19-2019, 03:09 PM   #2
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
I don't believe the engine heat is what kills the pumps. I feel it's coolant being old and carrying a charge (it should be dielectric) that leads to the pumps failing.
As the coolant ages it picks up more contaminates and starts to carry a charge. That causes the pump to work harder, amp draw rises. Once that draw reaches a point the controller reaches a limit and shuts down. The pump physically still works, it's just drawing too much power to run.
Or that's my theory.
Blu3RSX27.50
      01-19-2019, 04:09 PM   #3
What about just making some sort of heat shield for the e-pump ?
We don't really know how much longer the new revised e-pump will last. But IF it lasts another 60- 80K I think that's about right for a water pump.
Blu3RSX27.50
      02-06-2019, 03:43 AM   #4
juld0zer
Agreed on the lifespan.
It's not that hard to get to. Just awful doing the job on your back and copping a mouthful of residual coolant.
Dackelone10588.50
      02-18-2019, 11:59 AM   #5
iminhell1
C2H5OH
iminhell1's Avatar
Well
      02-20-2019, 11:01 PM   #6
gjm120
Drives: 2013 128i, 2021 230i
If this is correct, another reason to do frequent coolant changeouts!
      02-23-2019, 06:28 AM   #7
juld0zer
The pump impellor is usually physically stiff to turn with your fingers, which I suppose can increase the current draw.
Perhaps the lubricant properties of the coolant is insufficient?
