05-08-2019, 01:54 PM | #1 |
Rep 68
External Power Source During Programming
Gentlemen,
I'm trying to minimize voltage fluctuation while programming the car to avoid any issues. Would connecting my car with jumper cables to another car help with this? What should the voltage be around? Should I do it from the front or the back if that matters? Thank you in advance. |
05-10-2019, 02:27 AM | #2 | |
M119
118
Rep 101
The positive connection and ground post under the hood should be used since there are electrical control units connected to the battery in the trunk. Best of luck with the coding!
2012 Jet Black E82 135i, DCT, PPK, MHD Stage 1 , VRSF UCP, HPF FMIC, Racing Dynamics LCP, Liqui-Moly leichtlauf high tech 5W-40.
05-10-2019, 03:24 PM | #4 | |
Rep 2,806
Have a look at the coding sub-forum over on E90 post and do some more other digging into this.
tracer bullet2419.00 |
05-10-2019, 03:41 PM | #5 |
Rep 48
Jumper cables and the charging supply from another vehicle won't be very stable.
I just checked AA's flashing instructions and they ask for 3A minimum. So a battery charger will work, but not a trickle charger/maintainer. |
05-10-2019, 07:53 PM | #6 |
Rep 3,550
05-11-2019, 05:49 AM | #7 | ||
Rep 6,196
05-14-2019, 08:04 AM | #8 |
Rep 3,547
I have not coded in over 5 years. But I did it successfully without any external power supply. I just hooked up my cable and laptop and made the changes. It should not take a long time, maybe 10 minutes.
I do not see a problem with hooking up a charger if you want to be sure you don't go too long and deplete the battery. But I don't think it is always necessary - I did not and it worked. I changed a couple settings so I can put my top down with the key fob as I walk up to my e88, enabled the digital speedometer the M cars have and too the "correction" off of it, and set the doors to unlock when I remove the key fob from the dash. Just a few little changes.
