04-10-2011, 11:36 AM | #1 |
Rep 462
What year did the N55 start for the 135i?
I'm in the market for a 135i, but want an N54 and not an N55. Is 2010 the first year of the N55? If yes are all 2010s N55 or is it a mix? If it is a mix whats the easiest way to tell the difference?
thanks |
04-10-2011, 11:39 AM | #2 |
Rep 611
The easiest way to tell the difference is first the exhaust note...it is much deeper on the N55. The other more simple way is check the engine bay. The engine is completely different.
2011 AW 135i - DCT - M Package - BMW Performance Suspension Kit - Berk Street Midpipes - Evolution Racewerks FMIC - JB4 - BMS Intake - BMS Downpipes
04-10-2011, 01:16 PM | #8 |
Rep 220
Seems to be intentionally vague by BMW's marketing department. "Twinpower", most everybody will assume that it's a twin turbo.
2012 Alpine White 135i | DCT | Dinan Stage 3 | ER Charge Pipe | P3 Cars Boost Gauge | Performance Suspension | Terracotta Leather | M Sport Pkg | Premium Pkg | Heated Seats | Comfort Access |
04-10-2011, 01:42 PM | #9 |
Rep 2,070
04-10-2011, 03:34 PM | #10 |
Rep 22,992
NEGATIVE! That is NOT correct! Just look at RealOEM.com for build dates to confirm what I am saying bellow. The build also varies on wether you are looking at a USA or ROW (EU) spec car. Seems BMW made some small batches of N55's way before the real production started. I suspect that was to build press and car show cars. The first N55's were built from Sept/2009 thru Dec/2009. But in very small (limited) numbers. MOST (2010's) were N54's - like my 135i (US spec)was built on Dec/2009. I have a N54. Basically the N55's were mostly 2011 models. 2011 models started to be built around March 2010. BUT some early 2011 models still had the N54 too! SO... there is no real solid answer. You HAVE to look at the car you are buying/servicing. Dackel |
mwpa7119.50 |
04-10-2011, 03:51 PM | #11 |
699
Rep 3,267
Drives: 2010 128i
If you follow the 1M subforum, BMWNA's M rep says that the "TwinPower" name refers to the combination of turbocharging and direct injection. He acknowledged that, by this definition, the N54 is in fact a "TwinPower" engine although it was not marketed as such. (Although it may be in the case of the 1M?)
Personally I think BMW has really gone off the deep end when it comes to naming things. They really need to simplify. WTF is up with "Z4 sDrive 35is" or "X5 xDrive35i Sport Activity," for example? How did no one at BMW realize how stupid these names sound?
____________________________ |
04-11-2011, 01:51 AM | #12 | |
Rep 347
"you blink I shift" DCT
04-11-2011, 08:19 AM | #13 |
Rep 3,446
It's a pretty solid bet that if the car has DCT it also has N55. It would not have made sense to certify the DCT/N54 combination and then only build a handful.
See my photography at http://ronscubadiver.wordpress.com
10-17-2023, 03:47 PM | #14 |
Humanist
272
Rep 398
Nope. 335iS and the Z4 3.5iS both had N54 twin turbo engines with DCT transmissions. Guessing the 135iS was the same, just not positive about that model.
10-17-2023, 04:55 PM | #15 |
Rep 43
Generally, 2010 and older will be N54, 2011 and newer are N55, but just look in the engine bay to be sure. First image is the N54 - no lettering on the engine cover, two vacuum canisters at the front passenger corner of the bay. Second image is N55 - TwinPower Turbo moniker on engine cover, and air intake behind the engine cover
10-18-2023, 12:55 AM | #16 | |
Rep 7,224
I like the 19" 313s on the 335is better; nice concave look to them.
01-04-2024, 03:09 AM | #17 |
Rep 7
Were RHD markets different? Because I have a MY10.5 135i which is an N55/DCT. Build date June 2010 going by the VIN. Redbook here in Aus shows the MY10.5 cars being built from April 2010 onwards.
