05-03-2014, 05:32 PM | #1 |
Rep 212
aFe headers?
I hope this isn't a repost, but I just noticed that aFe sells headers for the 128i?
http://afepower.com/shop/details_new...0L&&brandID=99 I can't seem to find a review on these, so feel free to post one here. |
05-03-2014, 07:37 PM | #2 |
Rep 4,040
Drives: 130i coupé ;)
it is a repost - see e90post n52 section
The fit is good. It is unknown if results are measurable. Their dyno is for afe inatake + headers + stock exhaust e91. best use of these headers is probably to minimize noise & have "headers "on your loud exhaust if you did secondary cat delete and some no muffler solution.
05-04-2014, 12:15 PM | #3 |
Resident Tamed Racing Driver
298
Rep 4,697
Just your usual cheap headers. Wouldn't expect more than half a CAT delete in terms of power. Their claims are just silly, though equally optimistic to their dyno.
05-04-2014, 05:06 PM | #5 | |
Rep 4,040
My only concern is Cat placement. If you have a choice - do you place them in the header or secondaries? Most of not all N/A engined M cars seem to do the seconaries...
05-04-2014, 08:24 PM | #6 |
Rep 212
http://www.realoem.com/bmw/showparts...19&hg=18&fg=10
Where is the cat and resonator in this pic? I just see the "box" which I thought was only the resonator. |
05-04-2014, 10:41 PM | #7 | |
Rep 4,040
05-05-2014, 07:07 AM | #10 |
298
Rep 4,697
05-05-2014, 07:43 AM | #11 | |
Rep 4,531
For example, in SCCA STX, you have to run cats in OEM places (well within 6" of OEM). But, if you have 2 cats (like my N51 128 does) I can relocate the primary and combine the cat into the secondary. AKA, I can run superspring headers, and 100 cell count cats in the 1st section and follow the rules, and make a ton of power doing so. |
05-05-2014, 08:49 AM | #12 | |
298
Rep 4,697
05-05-2014, 09:01 AM | #13 |
Rep 212
What are your thoughts on just keeping the stock "headers" (exhaust manifold) and delete the cats in section 1? Is there a common/popular way to do this? It won't cause a CEL would it?
05-05-2014, 10:44 AM | #14 | |
298
Rep 4,697
Pros -Gain 2-6hp(which you can't physically feel) Cons: -Get nothing near the gains from at proper set of headers(20hp+) -Eliminate the free factory set of high flow cats that make a catless header install in our cars daily driver friendly in terms of odor -Rust on the welds in a year or two It won't cause a CEL as it is after the O2 sensors. The common way to do it would be to cut and weld, which should give you rust on the pipe down the road as I mentioned above.
05-05-2014, 01:25 PM | #15 | ||
Rep 9,004
Also false, see my first response. |
05-05-2014, 01:27 PM | #16 |
Rep 9,004
Overpriced catalyst that have shown 0 gains over more abundant options like Random Technology. You sure do like to throw around brand names, don't you?
05-05-2014, 03:03 PM | #17 | |
298
Rep 4,697
Quick then, time to bolt up that AFE intake for 12hp and 16 ft/lbs of torque!
And no, I'm not here to "throw around names". I recommend brands that actually make a nice thing. You can find plenty of posts of me trashing companies like HRE back when they made crap products, or any number of modern suspension names like BC and Broadway Static. *Edit* I am amused that for a quick Google of Random Technology yielded a link to HPF(lol) selling them, and then a guy on the Prelude forum talking about how they completely failed on him. Not looking great.
05-05-2014, 04:42 PM | #18 | |
Rep 4,531
In case you forgot, I'm doing a full-prep build for STX. So, here are the rules: E. Catalytic converters: Any catalytic converters are allowed, but must attach within 6” (152.4 mm) of the original unit. Multiple catalytic converters may be replaced by a single unit. The inlet of the single replacement converter may be located no further downstream than 6” (152.4 mm) along the piping flow path from the original exit of the final OE converter. The extents of an OE converter are defined by the expansion chamber in which the catalyst is contained, regardless of placement within larger exhaust sections. Replacement converters must have a minimum catalyst density of 100 cells per inch and minimum substrate length of 3” (76.2 mm). AKA - Catless headers and a secondary cat is allowed. |
05-05-2014, 04:54 PM | #19 | |
Rep 9,004
And I'm glad you found 1 reported failure of a RT product when it's cost and availablility far exceeds those of HJS (which I didn't here about until people started to fanboy Super Sprint products) So why don't you show me those Super Sprint header dynos on the N52, or those Evolve tuned 128s that make so much power over AA/OE cars, along with break down on how those HJS headers are a superior product to other HiFlow cats on the market. I'll keep waiting. Does Evolve make a nice product, sure. Does SuperSprint? Of course. Does that mean anything outside of these "Premium" products isn't as good or better - absolutely not. |
05-05-2014, 05:38 PM | #21 | |
Rep 9,004
If you don't have a car with downstream catalyst (as pictured in the diagram above) then what? |
05-05-2014, 05:38 PM | #22 |
Rep 9,004
