      01-18-2016, 10:34 AM   #1
Norm1M
Drives: 2011 BMW 1m coupe
Best bolt on FMIC you can install on a 1M
Hi,
I'm looking to upgrade the factory OEM FMIC for something more efficient. I'm doing around 5-10 track day during the summer.
I already have installed an Evolution Racewerks charge pipe with TIAL BOV.
I'm looking for something bolt on with no cut out.
Thx
      01-18-2016, 12:55 PM   #2
EvoKnvl
Drives: Valencia Orange 1 Series M
I got the ETS 5" intercooler. Install was fairly simple. I have it paired with the ER CP as well. Works great!
      01-18-2016, 02:06 PM   #3
Jet Mech
Jet Mech's Avatar
66
Drives: 2011 1M Coupe VO
Forge...Harold at HP autowerks has them. Check the vender section.
2024 X3 M40i
2011 1M Coupe VO (Sold)
2015 MB GLK 250 Blutec Deez (Sold)
2001 S54 M Coupe (Sold)
1998 M3/4 (Sold)
      01-18-2016, 02:32 PM   #4
1&done
1&done's Avatar
Drives: 2011 VO 1M
I went w/ Forge because I did not want to cut anything m; fitment and quality is top notch. If cutting isn't and issue then the slightly larger 7"ETS would be a good choice as well.
I believe the Evolve is a direct for as well GL
///1M #643 of #740
      01-18-2016, 11:08 PM   #5
1'M Blue
Oman
255
Drives: 1M
ETS 5" .. fit and performs good .
      01-24-2016, 03:44 PM   #6
Cursed1
Drives: Lots of them
I went with the Cobb unit. No permanent modifications to the car and like the others it has a stepped core.
      01-25-2016, 03:12 PM   #7
Tinsta
Tinsta's Avatar
189
Drives: 1CSL
Got a Wagner evo intercooler installed, and no issues on track, definitely recommended.
      01-25-2016, 07:24 PM   #8
SSR-125
Drives: e82 09' 135i
I have a 7" VRSF intercooler. Trimming was required but not a lot like you'd think.. Very easy install.. Took me 1 hour to remove the OEM stock intercooler and install the new one including the trimming. Hope this helps, good luck!
Chris
      02-02-2016, 09:45 PM   #9
BMW Gator
BMW Gator's Avatar
61
Drives: C8/R8/1M/X5/JK Rubicon/FJ40
Forge - quality and fitment top notch
      02-03-2016, 03:35 PM   #10
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      02-03-2016, 03:58 PM   #11
kong24680
Drives: Silverstone Metallic F06 M6 Gr
From what I have read, the absolute best Intercooler on the market should be the Ambient Thermal Management stepped Intercooler. They use to make intercooler a for Helix and now sell them as their own brand.
      02-29-2016, 12:22 PM   #12
martymil
Drives: Garage is to big to list.
From what I have tested the best you can buy for the stock location is the
Wagner Evo 2 Competition http://www.wagner-tuning.com/EVO-2-C...1044_p_90.html
Here is a good review http://www.n54tech.com/forums/showthread.php?t=31479
      03-06-2016, 06:24 PM   #13
nick_r
Drives: Bmw 1m
Anybody experience with a evolve/pwr intercooler?
I prefer p&p and tube and fin. So i think that's the only option.
      03-06-2016, 06:34 PM   #14
martymil
The Wagner is tube and fin and far superior to anything on the market pretty much plug and play
The only thing you have to change is the connections from the factory pipes
      03-07-2016, 10:18 PM   #15
lightning
Singapore
69
Drives: 1M Pure S2
i'm on the wagner intercooler, and fitting is spot on, very very good. However, with regards to performance, it is only marginally better than stock.
If you're thinking of running more boost and higher hp, go for bigger solutions such as the VRSF 7" intercooler. I've heard many good things about it.
      03-07-2016, 10:35 PM   #16
martymil
Sorry dude there are four Wagner Ic you must have gotten the no frills bottom of the range
There is no in hells chance a vrsf will come even close to a Wagner tube and fin
      03-08-2016, 09:10 PM   #17
lightning
Singapore
69
Drives: 1M Pure S2
Nice... I'm not sure which one I got, but I was one of the few that bought it when it first came out.
      03-09-2016, 08:34 PM   #18
phunky_monkey
Drives: VO 1M, Radical SR3
I have a Wagner tube and fin on the way. My research told me it was the best kit option on the market, hopefully it lives up to it.
For me the biggest concern was ensuring it was lightweight, with good flow so as to not disrupt throttle response, and third priority was cooling capacity as I'm not chasing big power so knew all the top-tier intercoolers would have adequate cooling for my needs. The Wagner seemed to tick those boxes better than most, and certainly had the best combination of the three.
      06-09-2016, 05:42 PM   #19
nick_r
Drives: Bmw 1m
Another tube and fin intercooler kit for the 1m.
No cutting ...
What do you think?
http://www.proalloy.co.uk/cgi-bin/si...act=det&p=2071
Can't choose
Wagner comp evo1, pro alloy or pwr/evolve
All tube and fin intercooler kits
      06-10-2016, 01:43 PM   #20
martymil
The Wagner evo comp 2 preformed flawlessly at my last track day, temps never exceeded 100 f
The ic is the best you can get in terms of cooling in the stock location but in summer it does struggle
These cars where never designed to run the power we are getting out of these cars in the Australian heat
I'm looking into upgrading to the jd75/advan big Ic
Seen the results and they where very impressive
But jd75 will have to step in and let you guys know the results
Look at it this way you will never need to upgrade the Ic ever again on these cars
      06-10-2016, 01:47 PM   #21
Originally Posted by Norm1M View Post
Hi,
Thx
Besides a larger FMIC... I think you ought to research getting a new oil cooler or add-on oil cooler.
Dack
      06-11-2016, 04:19 PM   #22
xjan
Drives: BMW 1M
Mishimoto
