      06-01-2016, 02:32 AM   #1
arctic_fox
Drives: 2017 m550d
Cobb AP v3 logging issues - solved
Hi.
Having problems with the logging feature of my Cobb accessport V3. I get it connected to the car, and I can load and delete OTS maps. I can also read gauges and error codes. If I start a logg everything works fine UNTIL the car moves. It then just quits from the logging/gauge menu and disconnects from the car. I then have to stop/start the car to have it reconnected. This happens everytime I try logging. As long as the car stand still evenyting is just fine.
I have been in contact with Cobb which issued me a new cable, which did not help any. Tried to contact them again, but no response so far.
Anyone else had similar problems?
/Johannes
      06-17-2016, 11:23 AM   #2
arctic_fox
Drives: 2017 m550d
Update on this : Ordered a new AP from COBB, but the problems persist. The logging even quits if I let the car roll forward without any load on engine/alternator etc. It quits the logging when it has moved approx 1.5 metres.
I have checked battery voltage (12,6 V at stop, 14,55V at idle) and connections. Everything looks great.
Anyone else had this or similar issues?
      07-22-2016, 05:13 PM   #3
arctic_fox
Drives: 2017 m550d
I found the reason for the gauge and logging issue. Had to disconnect the Awron gauge. No it works great.
      07-27-2016, 11:18 AM   #4
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
Guessing that fancy all-n-one gauge uses the OBD2 port also?
Generically speaking the AP can be the only thing connected when in use.
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
