12-01-2023, 12:37 AM | #1 |
Rep 269
remove passenger seat?
I am thinking that a dog might be in my future, perhaps up to 70#. As my primary vehicle is the 128i, the dog would get a lot of 'ride time'. Is it possible to remove the passenger seat to give the dog a larger, flatter area? Any issues with either the airbags or the warning lights for them?
E9x M3 front & rear suspension arms; BMW Performance brakes upgraded to drilled rotors in rear; BMW performance shifter; BMW Performance Exhaust; Wave Trac LSD with modified 'nannies'; BMW Euro Intake box; BMW Aluminum Strut Tower bar; ECS front and rear sway bars; 3 stage intake with BPC software; BMW style 78, 17 x 8" wheels with Bridgestone RE 980AS 225/45-17 tires; Koni Special Active struts/shocks, E9x M3 RTABs.
12-01-2023, 09:04 AM | #2 |
Riffraff
80
Rep 90
Love that idea.
If you remove the seat it will definitely trip an airbag light. I'm not certain but i think you may be able to code out the presence of the equipment using a coding tool like Bimmergeeks. I would search for info on installing race seats (as those have no airbags) and see if that leads you anywhere. |
12-01-2023, 11:51 AM | #3 |
J
374
Rep 700
Drives: BMW 128i
Tbh, you're better off removing part of the back seat. A dog that big should have some sort of tether. The front seat at least provides a bit of protection if you get rear ended.
12-02-2023, 11:51 PM | #4 |
Rep 269
Thanks for replies. I thought that I could use the front seatbelt as a tether for a dog, but maybe that isn't realistic? It's been over 30 years since last having a dog, and back then, he liked to lie on the passenger seat. I figure that being on the floor would prevent a dog from being thrown off the seat.
12-03-2023, 08:12 AM | #5 |
Rep 783
Drives: 2010 328ix E91, 2011 128i E82
I've not considered this idea for my 128i but I have thought about it for my C5 Corvette for road trips (when my wife is not going along). My dog is medium sized (40 lbs) and I've thought about some sort of wooden base with storage underneath and a padded area/bed on top for her. I would want to bolt the base down on the seat attachment points and use some sort of restraint in the top section for her. No issues with airbags as the Corvette does not have airbags in the seats.
K9Leader 2010 328i x-Drive, E91 - Space Gray/Black 2011 128i E82 6MT - Crimson Red/Black |
12-08-2023, 11:46 AM | #6 |
Rep 269
Not sure why my reply from a couple of days ago didn't get posted. K9Leader, you have a nice looking pooch. I don't know if I need to build a platform as I expect the floor to be fairly flat. I'm concerned whether the seats are held in place with bolts or have studs extending up from the floor panel with nuts above the seat track mounts? The seat belt could still be a tether even if a dog is on the floor, or is the female end too high in practice?
