      02-22-2018, 07:29 AM   #1
SixBanger
Drives: 08 135i
Rear Main Seal Tool
So, while I 'll be replacing my clutch this weekend I'm going to be replacing the rear main seal. No matter how compliant you are with maintenance, when you turn your back the car will shit on you. Anyway, What's the most popular go to tool I can use or rent that'll will remove and install the seal properly?
      02-22-2018, 02:59 PM   #2
desertman123
E82 Mudflap Ambassador
desertman123's Avatar
Drives: '08 128i
1992 Honda Beat  [9.50]
2008 BMW 128i  [10.00]
2014 BMW 528i  [10.00]
Not sure if our cars need some special gadget but here's what I used for the differential output flange seals. Literally just a 'seal remover tool', I got it for $7 at Harbor Freight.
To install the seal just use a bearing/race press kit, or a socket thats sliiiightly smaller than the overall diameter of the seal.
Take note of the depth of the old seal. I don't know if there's a lip that stops it, but on my diff there was not, and I ended up pressing the seal too deep, thus ruining it. You may wanna buy 2 seals, and return 1 if you successfully press the first one in.
edit: SCRATCH THAT doesn't look like that's the proper technique. Check out this video
