Closed Thread
      06-27-2018, 11:58 AM   #1
SSR Performance
SSR Performance's Avatar
Drives: S55 -F80 / N54 -135i / N55-535
Smile **N54 VRSF Silicone Inlet Special w/ Install!!! ($549 parts + labor) **
If we weren't giving you guys enough discounted rates already, here is another one!
Take advantage of our special while you still can!
We know how expensive this modification can be, and we constantly offer specials to help out other car enthusiasts just like us! Here at SSR Performance, we try to give our fellow car enthusiast the best deals around town so check it out!
VRSF Stock Side Silicone Inlets + Installation for just
$549!!!
VRSF OEM Location Silicone Upgraded Inlets for your N54 135i/1M/335i/335is/535i/Z4
Replace your restrictive factory intake system with the VRSF Silicone Performance Intake Kit featuring high quality, one piece, steel wire reinforced silicone construction. Gains of up to 60whp can be realized by replacing the restrictive factory intake inlets with this bolt on kit.
The VRSF side OEM location inlet kit replaces the restrictive stock intake tract with our high flowing 2" one piece intake which doesn't require the relocation of any components in your engine bay. This kit will work with any intake that fits the stock inlets including and not limited to the VRSF DCI, Injen, aFe and OEM intake. This kit works with both RHD and LHD 135i, 1M, 335i, 335is, 535i, Z4 as well as XI variants.
This inlet kit will include everything you need to replace the restrictive OEM inlets. We also offer an option dual cone intake (DCI) kit which includes the highest quality filters available on the market. The S&B intake filters greatly increase flow in the mid to upper RPM range while introducing a more aggressive engine note. Note: The outlet offered currently only fits the 335i.
This item fits the following BMWs:
-2007-2010 E90/E91/E92/E93 BMW 335i & 335xi N54
-2011-2012 E92 BMW 335is N54
-2007-2010 E60 BMW 535i & 535xi N54
-2008-2012 E82 BMW 135i & 135is N54
-2009-2015 E89 BMW Z4 35 N54
Look at those gains!
We will be offering this special for a limited time only and while supplies last! So go ahead and give us a call now to schedule your appointment
(800) 438-2808 or email us now at info@SSR-Performance.com!
Closed Thread
135i, 335i, 535i, downpipes, exhaust, inlets, modification, n54, ssr performance
